Lots of menu items disappeared recently from my main screen (Apps, Dashboards, Demandshaper, also many items from the sidebar - including Backup), so I’ve done a clean install of the most recent version.
After the install I am seeing everything again, but when restored my data I can not see any apps, only this message:
Also (not sure if related) in the log these keep showing up:
LAST ENTRIES ON THE LOG FILE
2022-03-14 09:46:14.206|WARN|PHPFina.php|post() padding max block size exeeded id=8, 4656456 dp
2022-03-14 09:46:14.225|WARN|PHPFina.php|post() padding max block size exeeded id=15, 4656456 dp
2022-03-14 09:46:14.231|WARN|PHPFina.php|post() padding max block size exeeded id=16, 4656456 dp
2022-03-14 09:46:14.236|WARN|PHPFina.php|post() padding max block size exeeded id=17, 4715326 dp
2022-03-14 09:46:14.241|WARN|PHPFina.php|post() padding max block size exeeded id=18, 4715326 dp
2022-03-14 09:51:14.248|WARN|PHPFina.php|post() padding max block size exeeded id=3, 4656486 dp
2022-03-14 09:51:14.254|WARN|PHPFina.php|post() padding max block size exeeded id=4, 4656486 dp
2022-03-14 09:51:14.260|WARN|PHPFina.php|post() padding max block size exeeded id=5, 4656486 dp
2022-03-14 09:51:14.266|WARN|PHPFina.php|post() padding max block size exeeded id=6, 4656486 dp
2022-03-14 09:51:14.272|WARN|PHPFina.php|post() padding max block size exeeded id=7, 4656486 dp
2022-03-14 09:51:14.278|WARN|PHPFina.php|post() padding max block size exeeded id=8, 4656486 dp
2022-03-14 09:51:14.295|WARN|PHPFina.php|post() padding max block size exeeded id=15, 4656486 dp
2022-03-14 09:51:14.299|WARN|PHPFina.php|post() padding max block size exeeded id=16, 4656486 dp
2022-03-14 09:51:14.303|WARN|PHPFina.php|post() padding max block size exeeded id=17, 4715356 dp
2022-03-14 09:51:14.307|WARN|PHPFina.php|post() padding max block size exeeded id=18, 4715356 dp
2022-03-14 09:56:14.313|WARN|PHPFina.php|post() padding max block size exeeded id=3, 4656516 dp
2022-03-14 09:56:14.318|WARN|PHPFina.php|post() padding max block size exeeded id=4, 4656516 dp
2022-03-14 09:56:14.324|WARN|PHPFina.php|post() padding max block size exeeded id=5, 4656516 dp
2022-03-14 09:56:14.330|WARN|PHPFina.php|post() padding max block size exeeded id=6, 4656516 dp
2022-03-14 09:56:14.336|WARN|PHPFina.php|post() padding max block size exeeded id=7, 4656516 dp
2022-03-14 09:56:14.341|WARN|PHPFina.php|post() padding max block size exeeded id=8, 4656516 dp
2022-03-14 09:56:14.358|WARN|PHPFina.php|post() padding max block size exeeded id=15, 4656516 dp
2022-03-14 09:56:14.363|WARN|PHPFina.php|post() padding max block size exeeded id=16, 4656516 dp
2022-03-14 09:56:14.368|WARN|PHPFina.php|post() padding max block size exeeded id=17, 4715386 dp
2022-03-14 09:56:14.373|WARN|PHPFina.php|post() padding max block size exeeded id=18, 4715386 dp
Any ideas how to fix this, please?
