I am new to the community and have progressed quite a lot with the setup of my data and graphs. Great tips and help from the community, thanks.
I do however need some assistance.
I have created an app but it does not show any data, only the loading circle spinning in the middle. it also does not allow me click the spanner to edit or delete.
I am building my own system with custom software on Pi posting to EMONCMS.
I have created an APP in EMONCMS but it does not update any values nor allow me edit via clicking on spanner.
I’ve just taken a look at your account and was able to reproduce the issue you mention. I have asked @TrystanLea to take a look. Trystan designed the app module for Emoncms.
I think it could be something to do with the fact you don’t have much data in your account. The monitor seems to drop off frequently and was last active 10hrs ago.
Hi all. I’m very new and slowly getting through setting things up, and I too have come across this issue.
Pressing the config wrench also does nothing.
It’s a Time of Use app. I will add that I don’t yet have a full day of data captured, if that is anything that may contribute to this.
EmonCMS Version : low-write 9.8.25 | 2017.12.08
This is a local self build.
In the Chrome console it is throwing up this:
Uncaught TypeError: Cannot read property 'toFixed' of undefined
at bargraph_load (view?name=Time of use&readkey=###BLANKED###:753)
at show (view?name=Time of use&readkey=###BLANKED###:400)
at Object.config.showapp (view?name=Time of use&readkey=###BLANKED###:353)
at Object.init (config.js:30)
at view?name=Time of use&readkey=###BLANKED###:377
Thanks for reporting. Could you try Adding a new app then doing a screen capture of the feeds you are selecting when you first configure the app. I think it could be due to selecting feeds which contain at least 24hrs of data.
