- $("body").css('background-color','#222');
          - $(window).ready(function(){
          -     $("#footer").css('background-color','#181818');
          -     $("#footer").css('color','#999');
          - if (!sessionwrite) $(".openconfig").addClass('hide');
          - // Configuration
          - config.app = {
          -     "use":{"type":"feed", "autoname":"use", "engine":"5", "description":_("House or building use in watts")},
          -     "solar":{"type":"feed", "autoname":"solar", "engine":"5", "description":_("Solar pv generation in watts")},
          -     //"export":{"type":"feed", "autoname":"export", "engine":5, "description":"Exported solar in watts"},
          -     "use_kwh":{"optional":true, "type":"feed", "autoname":"use_kwh", "engine":5, "description":_("Cumulative use in kWh")},
          -     "solar_kwh":{"optional":true, "type":"feed", "autoname":"solar_kwh", "engine":5, "description":_("Cumulative solar generation in kWh")},
          -     "import_kwh":{"optional":true, "type":"feed", "autoname":"import_kwh", "engine":5, "description":_("Cumulative grid import in kWh")},
          -     "kw":{"type":"checkbox", "default":0, "name": "Show kW", "description":_("Display power as kW")}
          -     //"import_unitcost":{"type":"value", "default":0.1508, "name": "Import unit cost", "description":"Unit cost of imported grid electricity"}
          - config.name = "<?php echo $name; ?>";
