Alternate to Madoka BRC1H52W
Daikin EDLA04E2V3 ASJP
Madoka BRC1H52Wroom thermostat
I’ve got this system set up quite nicely now , had it for nearly two years, however I note that the room thermostat is slow to respond to fluctuations in room temperature and the hystericist doesn’t help either, consequently there are - through the day - periods of overheating and underheat , particularly buddy winter , as opposed to a constant comfortable temperature
is there an alternative hardware device that can connect in place of this madoka that can connect to the MMI or system somehow ?
this was installed by octopus uk in feb 24
Forgive me this is the wrong forum please advise on the correct sub forum on the site I came here because you’re all very experienced reading your posts
TIA
edit:
I did try to use the madoka assistant app and successfully connected to the thermostat through Bluetooth … but the apo only allowed me to do a firmware update. after the update the app still would not let me change any settings… it seems that it’s disabled in some way
If you run home assistant you can set this up to control the temperature rather than using the madoka.
done that. didn’t meet requirements and other issues rendered this unworkable
so, again, question was…, with respect … Do you have insight intro a replacement or alternate device please?
edit:my english hope ok
brc1hhdak is the actual part
