Welcome, Stephen, to the forum.
There isn’t a way to “turn on” your feeds - they will update when data arrives in emonCMS from emonHub and is processed. So you need to start where the data comes in and follow it through.
Have you looked at emonHub? This is where the data from the analogue part (the energy monitor) first enters the Raspberry Pi. If you go to Setup → Emonhub (the loudhailer icon), it should open showing the emonHub log. Every 10 s, it should update with new values, something like
2024-05-01 16:48:09,745 DEBUG EmonPi2 279529 NEW FRAME : OK 5 195 87 6 0 0 0 0 0 0 0 60 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 200 0 0 0 46 0 0 0 (-0)
2024-05-01 16:48:09,748 DEBUG EmonPi2 279529 Timestamp : 1714578489.745139
2024-05-01 16:48:09,749 DEBUG EmonPi2 279529 From Node : 5
2024-05-01 16:48:09,749 DEBUG EmonPi2 279529 Values : [415683, 0, 0, 0, 0.6, 0, 0, 0, 0, 0, 0, 0, 0, 200, 46, 0, 0.0]
2024-05-01 16:48:09,750 DEBUG EmonPi2 279529 Sent to channel(start)' : ToEmonCMS
2024-05-01 16:48:09,751 DEBUG EmonPi2 279529 Sent to channel(end)' : ToEmonCMS
2024-05-01 16:48:09,872 DEBUG MQTT Publishing: emon/emonpiCM_5/Msg 415683
2024-05-01 16:48:09,874 DEBUG MQTT Publishing: emon/emonpiCM_5/power1 0
2024-05-01 16:48:09,875 DEBUG MQTT Publishing: emon/emonpiCM_5/power2 0
2024-05-01 16:48:09,877 DEBUG MQTT Publishing: emon/emonpiCM_5/power1pluspower2 0
2024-05-01 16:48:09,878 DEBUG MQTT Publishing: emon/emonpiCM_5/vrms 0.6
2024-05-01 16:48:09,880 DEBUG MQTT Publishing: emon/emonpiCM_5/t1 0
2024-05-01 16:48:09,882 DEBUG MQTT Publishing: emon/emonpiCM_5/t2 0
2024-05-01 16:48:09,883 DEBUG MQTT Publishing: emon/emonpiCM_5/t3 0
2024-05-01 16:48:09,885 DEBUG MQTT Publishing: emon/emonpiCM_5/t4 0
2024-05-01 16:48:09,887 DEBUG MQTT Publishing: emon/emonpiCM_5/t5 0
2024-05-01 16:48:09,889 DEBUG MQTT Publishing: emon/emonpiCM_5/t6 0
2024-05-01 16:48:09,891 DEBUG MQTT Publishing: emon/emonpiCM_5/pulse1count 0
2024-05-01 16:48:09,892 DEBUG MQTT Publishing: emon/emonpiCM_5/pulse2count 0
2024-05-01 16:48:09,894 DEBUG MQTT Publishing: emon/emonpiCM_5/E1 200
2024-05-01 16:48:09,896 DEBUG MQTT Publishing: emon/emonpiCM_5/E2 46
2024-05-01 16:48:09,898 DEBUG MQTT Publishing: emon/emonpiCM_5/missed 0
2024-05-01 16:48:09,899 DEBUG MQTT Publishing: emon/emonpiCM_5/missedprc 0.0
If it is updating, look at the Inputs page and on the right there should be a column of times in green (up to 10 seconds since the data last came in) if that shows n/a
in red, the data isn’t getting into emonCMS.
Still in Setup, go to Admin at the bottom of the menu, and look there: you should see a lot of Services listed, all should be Active and Running, except possibly for demandshaper: Not found or not installed
I’m not a RPi or emonCMS expert, so when you report back what you’ve found, I’ll need to hand over to somebody who knows more.
