Advice on a potential power monitoring device
Hello, i am looking for a little advice / opinions.
I have a atlantic alfea heatpump installed since about 5 years.
I have been using BSB-LAN device to monitor some of the temperatures and access the settings. I would like to take another step forward with monitoring, and i gather that the next step should probably be to track the power consumption.
My question is, would something like this be suitable enough? Acrel ADL200-NK/WF - Aliexpress
I am severely limited budget wise with 4 kids, and would like to make savings where possible.
I like the fact that it outputs to mqtt which should be easy to bring into my existing systems.
I would just like to hear your thoughts, good or bad please.
Welcome, Crighton, to the OEM forum.
Generally speaking, those sorts of device tend to be accurate and reliable. It is Class 1 accuracy (roughly 1%) and the manual I found https://dedjh0j7jhutx.cloudfront.net/1473688186151542784%2F06df7c53e67868fa462031ebc5761f55.pdf seems to have everything you need to know, though some of the translations are “original” - I’ve no idea what “active valley energy” might mean.
It looks as if you’ll need a Modbus RS485 module where you will receive the data - the link you gave and the manual mention Wi-Fi, but with no further details.
There’s also the non-WiFi version which has a display instead, also RS485 & Modbus. https://www.acrelenergy.com/uploads/file/adl200-manual.pdf
You will of course need to break into your wiring to install this meter, I assume you know the local regulations with regard to this.
We use this SDM120 Modbus MID 45A - Shop | OpenEnergyMonitor, which is comparable, so there’s a lot of information in the forum here about the Modbus interface, should you need it.
