Advanced Filtering on heatpumpmonitor.org
Hi everyone,
Advanced filtering is now live on heatpumpmonitor.org - here’s what’s new!
  1. Additional filtering operators
  2. New side panel for viewing and editing filters
    • Search or look up filter fields/columns
    • Choose an operator
    • Enter or select values
    • Define ranges (using two filters - greater than X, less than Y)
    • Enable/disable filters
    • Edit/delete filters
    • Share filters via URL - all parameters encoded in the URL & “filter” field
  3. Backwards compatible with the original “filter” string
Additional operators
There is one additional text operator:
  • Does not contain (ne)
The additional numeric operators are:
  • Greater than (gt)
  • Less than (lt)
  • Greater than or equal (gte)
  • Less than or equal (lte)
  • Not equal (ne)
Anything else defaults to equals (the original behaviour).
The format is backwards compatible and works in URLs:
  • all previous query strings will work as before
  • mixed default (equals) and new operator: query:hp_output:5:gt,UFH:0 (output to be greater than 5, UFH quals to 0)
Other examples:
  • query:hp_output:5:gt,UFH:0,old_radiators:1,combined_cop:4:lt,combined_cop:3:gt
  • query:hp_output:5:gt,UFH:0,old_radiators:1,combined_cop:4:lt,combined_cop:3:gt,combined_flowT_mean:35:lt
You can also specify ranges, e.g.:
  • query:combined_flowT_mean:35:lt,combined_flowT_mean:33:gt
New “Filters” panel (here is a view without any filters - notice the “Filters” box below “Add fields”):
Adding a new filter (after pressing the big “+” button; selecting a column using a dropdown or typing in the name)
Entering a value (typing it in or picking up an existing value)
Viewing active filters
Editing an existing filter (after pressing the yellow edit button)
Disabling a filter (using the checkbox)
That’s all I think.
Big shoutout to the team for building such a solid foundation and making heatpumpmonitor.org so easy to extend!
Please give it a try and let us know what you think! Keen to hear your feedback and ideas for improvements.
Kind regards,
Kamil
Thanks so much for contributing this @kamilfb, it’s such a useful feature and very nicely implemented! :clap: :pray:
Hi Kamil,
Many thanks and I don’t want to appear pedantic, but in a couple of places in heatpumpmonitor.org there is the word “seperation”.
This may be a reserved word that I’m not aware of, but if not, the common spelling is “separation”.
All the best, David.
That will be my fault @dmajwool I will get it corrected.
