Hi.
Has anyone added to the emonTx K-type thermal sensor? I have a sketch for thermal sensor, but I can’t connect it to the original emonTX sketch, so it also moves to emoncms.org.
Thank You if someone helps me.
Here is the Tx sketch
EmonTx Pulse example
Part of the openenergymonitor.org project
Licence: GNU GPL V3
Authors: Glyn Hudson, Trystan Lea
Builds upon JeeLabs RF12 library and Arduino
THIS SKETCH REQUIRES:
Libraries in the standard arduino libraries folder:
- JeeLib https://github.com/jcw/jeelib
Other files in project directory (should appear in the arduino tabs above)
- emontx_lib.ino
/*Recommended node ID allocation
-ID- -Node Type-
0 - Special allocation in JeeLib RFM12 driver - reserved for OOK use
1-4 - Control nodes
5-10 - Energy monitoring nodes
11-14 --Un-assigned --
15-16 - Base Station & logging nodes
17-30 - Environmental sensing nodes (temperature humidity etc.)
31 - Special allocation in JeeLib RFM12 driver - Node31 can communicate with nodes on any network group
#define RF69_COMPAT 1
#define FREQ RF12_433MHZ // Frequency of RF12B module can be RF12_433MHZ, RF12_868MHZ or RF12_915MHZ. You should use the one matching the module you have.433MHZ, RF12_868MHZ or RF12_915MHZ. You should use the one matching the module you have.
const int nodeID = 9; // emonTx RFM12B node ID
const int networkGroup = 210; // emonTx RFM12B wireless network group - needs to be same as emonBase and emonGLCD needs to be same as emonBase and emonGLCD
const int UNO = 1; // Set to 0 if your not using the UNO bootloader (i.e using Duemilanove) - All Atmega's shipped from OpenEnergyMonitor come with Arduino Uno bootloader
#include <avr/wdt.h> // the UNO bootloader
#include <JeeLib.h> // Download JeeLib: http://github.com/jcw/jeelib
#include "EmonLib.h"
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 4
OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
DallasTemperature sensors(&oneWire);
DeviceAddress address_T1 = { 0x28, 0x7E, 0x0C, 0x0F, 0x0A, 0x00, 0x00, 0x44 }; // Huussi Hormi
DeviceAddress address_T2 = { 0x10, 0x5A, 0x5A, 0x8D, 0x02, 0x08, 0x00, 0x4F }; // Huussi Ulko
ISR(WDT_vect) { Sleepy::watchdogEvent(); }
typedef struct {
int power, pulse, T1, T2;
PayloadTX;
PayloadTX emontx;
const int LEDpin = 9;
// Pulse counting settings
long pulseCount = 0; // Number of pulses, used to measure energy.
unsigned long pulseTime,lastTime; // Used to measure power.
double power, elapsedWh; // power and energy
int ppwh = 1;
void setup()
Serial.begin(115200);
Serial.println("emonTX Pulse example");
delay(100);
sensors.begin();
rf12_initialize(nodeID, FREQ, networkGroup); // initialize RF
rf12_sleep(RF12_SLEEP);
pinMode(LEDpin, OUTPUT); // Setup indicator LED
digitalWrite(LEDpin, HIGH);
attachInterrupt(1, onPulse, FALLING);
if (UNO) wdt_enable(WDTO_8S);
void loop() {
sensors.requestTemperatures(); // Send the command to get temperatures
emontx.T1 = sensors.getTempC(address_T1) * 100 / 100,0;
emontx.T2 = sensors.getTempC(address_T2) * 100 / 100,0;
emontx.pulse = pulseCount; pulseCount=0;
Serial.print(emontx.power);
Serial.print("W ");
Serial.println(emontx.pulse);
send_rf_data(); // *SEND RF DATA* - see emontx_lib
Serial.print("W ");
emontx_sleep(10); // sleep or delay in seconds - see emontx_lib
digitalWrite(LEDpin, HIGH); delay(2); digitalWrite(LEDpin, LOW); // flash LED
// The interrupt routine - runs each time a falling edge of a pulse is detected
void onPulse()
lastTime = pulseTime; //used to measure time between pulses.
pulseTime = micros();
pulseCount++; //pulseCounter
emontx.power = int((3600000000.0 / (pulseTime - lastTime))/ppwh); //Calculate powerprint_to_serial
and here’s k-type sketcs
// FILE: max31855_demo0.ino
// AUTHOR: Rob Tillaart
// VERSION: 0.1.3
// PURPOSE: thermocouple lib demo application
// DATE: 2014-01-01
// URL:
// Released to the public domain
#include "MAX31855.h"
const int doPin = 8;
const int csPin = 11;
const int clPin = 13;
MAX31855 tc(clPin, csPin, doPin);
void setup()
Serial.print("Start max31855_demo0: ");
Serial.println(MAX31855_VERSION);
Serial.println();
tc.begin();
void loop() {
int status = tc.read();
Serial.print("stat:\t\t");
Serial.println(status);
float internal = tc.getInternal();
Serial.print("internal:\t");
Serial.println(internal);
float temp = tc.getTemperature();
Serial.print("temperature:\t");
Serial.println(temp);
delay(100+00);
