Adding PR6 pulse counter to V200 water meter and EmonPi
Hi all,
I just got a new water meter installed which I’d like to add to my EmonPi. It’s an Elster V200 and I’ll most likely order the Elster PR6 1:1 pulse counter.
Two questions:
  • has anyone done this before with a V200, PR6 and EmonPi?
  • does anyone have any lessons learned from connecting the PR6?
I’ve seen the posts between @glyn.hudson and @pb66 however I haven’t found a resolution on the forums.
Looking at the fitting instructions on the PR6, there are 6 wires. I’d probably only need the CH2P and GND but do I need to use a pullup resistor in there for the EmonPi?
I’ll add a RJ45 Expander as I’m already using the RJ45 port for the Energy Pulse Counter. The link to the pinout on this page redirects to the frontpage. Is there an RJ45 pinout diagram I can use to connect the PR6?
Thx for your help…
You can’t have two pulse inputs to the emon part of the emonPi. It’s simply not capable of it. I take it that was your plan?
You can, I believe, wire a pulse input to the Raspberry Pi itself, but there’s no provision for that in the standard SD card software. I can’t tell you how to wire it nor what you need in the way of software, that’s outside my area of expertise.
But you can wire the (water) pulse counter instead of the optical one, or possibly a lot more conveniently, you could wire the water pulses into an emonTH to read the pulses and send the count by radio to your emonPi.
Thx for the quick reply. Yes, that was the plan…
The easy solution was indeed to use the EmonTH and pulse sensor but as everything is in the same closet I was hoping it could be solved by using the EmonPi itself.
I found this post, I’ll try and see if I can make a 1 sensor version instead of a 12 input :slight_smile:
If you do that, how are you going to get the count into the Pi? Remember, the serial input is already in use by the “emon” front end that gives you the analogue energy monitoring and the energy pulse input. This is why you need to use the Pi’s GPIO and a script or a service running in the Pi itself, passing the data to emonHub or emonCMS directly.
And this is what I had at the back of my mind that does just that, but didn’t find earlier:
Coming back to the original question, as your meter uses an active pull-down, you will need a pull-up resistor to the appropriate voltage to provide a solid logic ‘high’ to the input pin.
And the pinout: emonTx3 User Guide — OpenEnergyMonitor 0.0.1 documentation
You can of course parallel the one-wire temperature sensors, but you can’t do that with the pulse input, which is a logical voltage level input.
Hi All.
I’ve just installed an emonPi measuring my electricity and Solar. I’m now looking at adding my gas and water.
I have a V200 water meter and planning on getting a PR6 pulse counter wired into an emonTH.
Can anyone advise on the pin wiring required - will a resistor be needed? From the diagram from @Cobalt I would use CH2P and GND - does this then need a resistor going into the emonTH?
Welcome, Henry, to the OEM forum.
I take it you’re referring to the diagram in post no.1 above.
You’re correct, you need to connect the meter’s GND to the emonTH GND (pin 3 on the screw terminals) and the meter’s CH2P to the emonTH Pulse input (pin 4). You should not need an external pull-up resistor because the internal pull-up is enabled in the software. (Line 233 in the sketch if you want to look.)
Sorry to resurrect an ancient thread, but in case it’s relevant to anyone else, I have this exact setup (Elster water meter with PR6 pulse counter). I had it setup with an emonPi counting pulses but was getting quite a few spurious pulses (think the PR6 is susceptible to noise). I tried various resistors but eventually fixed it with a cheap ESP32 board (Waveshare ESP32-S3-GEEK). Had one lying around but this would work with others. It has a tiny LCD screen where we can display the running pulse total and the total of discarded pulses. Plugs directly into the Pi’s USB. Just two connections:
  • black wire from PR6 → GND of ESP32
  • red wire from PR6 → GPIO6 of ESP32
Downloaded micropython binary and flashed it to ESP32 using esptool. Here’s the micropython I used. It only counts a pulse of at least 40ms; it persists the total to memory every 10 valid pulses; it prints litres:XX over serial every 10s for easy inclusion in emonHub; and a 2s hold of the little boot button resets the counters. It displays the running totals on its screen
from machine import Pin, SPI
import framebuf, time, json, array
# ── Hardware ──────────────────────────────────────────────────────────────────
PULSE_PIN = 6
LCD_SCLK, LCD_MOSI, LCD_CS, LCD_DC, LCD_RST = 12, 11, 10, 8, 9
# ── Config ────────────────────────────────────────────────────────────────────
DEBOUNCE_US    = 40_000   # ignore pulses shorter than 40 ms
SAVE_EVERY     = 10       # persist to flash every N valid pulses
SERIAL_EVERY_S = 10       # serial output interval
STATE_FILE = '/state.json'
# ── Colors — RGB565 byte-swapped for MicroPython framebuf ────────────────────
def _rgb(r, g, b):
    v = ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3)
    return ((v & 0xFF) << 8) | (v >> 8)
BLACK = 0x0000; WHITE = 0xFFFF
DARK  = _rgb(0,   0,  48); GRAY  = _rgb(120,120,120)
GREEN = _rgb(80, 220,  80); RED   = _rgb(220, 60,  60)
# ── ISR state — pre-allocated, no heap allocation in handler ─────────────────
_fall_us    = array.array('l', [0])
_ev_valid   = array.array('i', [0])
_ev_discard = array.array('i', [0])
def _isr(pin):
    if pin.value() == 0:                      # falling edge — pulse starts
        _fall_us[0] = time.ticks_us()
    else:                                      # rising edge — pulse ends
        t0 = _fall_us[0]
        if t0:
            dur = time.ticks_diff(time.ticks_us(), t0)
            if dur >= DEBOUNCE_US:
                _ev_valid[0]   += 1
            else:
                _ev_discard[0] += 1
            _fall_us[0] = 0
# ── Persistence ───────────────────────────────────────────────────────────────
def load_state():
    try:
        with open(STATE_FILE) as f:
            d = json.load(f)
        return int(d.get('count', 0)), int(d.get('discarded', 0))
    except:
        return 0, 0
def save_state(count, discarded):
    with open(STATE_FILE, 'w') as f:
        json.dump({'count': count, 'discarded': discarded}, f)
# ── ST7789 240×135 LCD driver (Waveshare ESP32-S3-GEEK) ──────────────────────
class Display:
    W, H   = 240, 135
    X0, Y0 = 40, 52     # hardware offsets for this specific panel
    def __init__(self):
        spi = SPI(1, baudrate=40_000_000,
                  sck=Pin(LCD_SCLK), mosi=Pin(LCD_MOSI),
                  polarity=1, phase=1)
        self._spi = spi
        self._cs  = Pin(LCD_CS,  Pin.OUT, value=1)
        self._dc  = Pin(LCD_DC,  Pin.OUT, value=0)
        self._rst = Pin(LCD_RST, Pin.OUT, value=1)
        self._cs.value(0);  time.sleep_ms(20)
        self._rst.value(0); time.sleep_ms(20)
        self._rst.value(1); time.sleep_ms(50)
        def r(c, *a):
            self._cmd(c, bytes(a) if a else None)
        r(0x36, 0x70); r(0x3A, 0x05)
        r(0xB2, 0x0C,0x0C,0x00,0x33,0x33); r(0xB7, 0x35)
        r(0xBB, 0x19); r(0xC0, 0x2C); r(0xC2, 0x01)
        r(0xC3, 0x12); r(0xC4, 0x20); r(0xC6, 0x0F)
        r(0xD0, 0xA4,0xA1)
        r(0xE0, 0xD0,0x04,0x0D,0x11,0x13,0x2B,0x3F,0x54,0x4C,0x18,0x0D,0x0B,0x1F,0x23)
        r(0xE1, 0xD0,0x04,0x0C,0x11,0x13,0x2C,0x3F,0x44,0x51,0x2F,0x1F,0x1F,0x20,0x23)
        self._cmd(0x21); self._cmd(0x11); time.sleep_ms(120)
        self._cmd(0x29); time.sleep_ms(20)
        self._buf = bytearray(self.W * self.H * 2)
        self._fb  = framebuf.FrameBuffer(self._buf, self.W, self.H, framebuf.RGB565)
    def _cmd(self, cmd, dat=None):
        self._dc.value(0); self._cs.value(0)
        self._spi.write(bytes([cmd])); self._cs.value(1)
        if dat is not None:
            self._dc.value(1); self._cs.value(0)
            self._spi.write(dat if isinstance(dat, (bytes, bytearray)) else bytes([dat]))
            self._cs.value(1)
    def show(self):
        x0, x1 = self.X0, self.X0 + self.W - 1
        y0, y1 = self.Y0, self.Y0 + self.H - 1
        self._cmd(0x2A, bytes([x0>>8, x0&0xFF, x1>>8, x1&0xFF]))
        self._cmd(0x2B, bytes([y0>>8, y0&0xFF, y1>>8, y1&0xFF]))
        self._spi.write(b'\x2C'); self._dc.value(1)
        mv = memoryview(self._buf)
        for i in range(0, len(self._buf), 4096):
            self._spi.write(mv[i:i+4096])
        self._cs.value(1)
    def text_s(self, s, x, y, fg, bg, scale=2):
        bw = len(s) * 8; stride = (bw + 7) // 8
        mono = bytearray(stride * 8)
        mfb  = framebuf.FrameBuffer(mono, bw, 8, framebuf.MONO_HLSB)
        mfb.fill(0); mfb.text(s, 0, 0, 1)
        for cy in range(8):
            row = cy * stride
            for cx in range(bw):
                bit = (mono[row + cx // 8] >> (7 - cx % 8)) & 1
                c   = fg if bit else bg
                px, py = x + cx * scale, y + cy * scale
                for sy in range(scale):
                    for sx in range(scale):
                        nx, ny = px + sx, py + sy
                        if 0 <= nx < self.W and 0 <= ny < self.H:
                            self._fb.pixel(nx, ny, c)
    def draw(self, count, discarded):
        self._fb.fill(DARK)
        self.text_s("Valid",        8,   8, GRAY,  DARK, scale=2)
        self.text_s(f"{count} L",   8,  30, GREEN, DARK, scale=3)
        self.text_s("Discarded",    8,  88, GRAY,  DARK, scale=2)
        self.text_s(str(discarded), 8, 110, RED,   DARK, scale=2)
        self.show()
# ── Main ──────────────────────────────────────────────────────────────────────
RESET_HOLD_MS = 2000
def main():
    count, discarded = load_state()
    unsaved = 0
    disp = Display()
    disp.draw(count, discarded)
    pin = Pin(PULSE_PIN, Pin.IN, Pin.PULL_UP)
    pin.irq(trigger=Pin.IRQ_RISING | Pin.IRQ_FALLING, handler=_isr)
    btn = Pin(0, Pin.IN, Pin.PULL_UP)   # BOOT button, active-low
    btn_down_ms = None
    last_serial = time.time()
    dirty       = False
    print(f"Water meter started — count={count} discarded={discarded}")
    while True:
        now_ms = time.ticks_ms()
        if btn.value() == 0:
            if btn_down_ms is None:
                btn_down_ms = now_ms
            elif time.ticks_diff(now_ms, btn_down_ms) >= RESET_HOLD_MS:
                count = 0; discarded = 0; unsaved = 0
                save_state(0, 0)
                _ev_valid[0] = 0; _ev_discard[0] = 0
                btn_down_ms = None
                print("litres:0")
                disp._fb.fill(DARK)
                disp.text_s("RESET!", 40, 55, WHITE, DARK, scale=4)
                disp.show(); time.sleep_ms(1000)
                dirty = True
        else:
            btn_down_ms = None
        nv = _ev_valid[0];   _ev_valid[0]   = 0
        nd = _ev_discard[0]; _ev_discard[0] = 0
        if nv or nd:
            count += nv; discarded += nd; unsaved += nv; dirty = True
            if unsaved >= SAVE_EVERY:
                save_state(count, discarded); unsaved = 0
        if dirty:
            disp.draw(count, discarded); dirty = False
        now = time.time()
        if now - last_serial >= SERIAL_EVERY_S:
            print(f"litres:{count}")
            last_serial = now
        time.sleep_ms(50)
main()
Quite a niche, but for ~£10 of hardware it’s worth it for anyone else looking at pulses counted getting ahead of the meter reading..
