I’m currently having a lot of trouble setting up IoTaWatt data inputs into my emoncms server (which is being hosted by an EmonPi). The IoTaWatt input simply doesn’t show up on emoncms. I have been able to set up emonTHs successfully. Below is the configuration I have in the IoTaWatt Web server setup:
@overeasy has set up an IoTaWatt specific forum at https://community.iotawatt.com/, you will probably get a speedier reply there. Knowledge and experience of the IoTaWatt is fairly limited on this forum.
