Hi. Could someone add the math plugin to this forum? Discourse Math
That will make it much easier to write out equations about things like heat loss, heat flow etc.
I was just about to post this - excellent idea!
I â@ flaggedâ this in case youâve not seen the first post in the thread.
Sure, we will look at adding that.
thanks!
Good, idea! Iâve added the plugin. Itâs now working ![]()
The code behind the above looks like
\sqrt{(-1)} \; 2^3 \; \sum \; \pi
\sum_{i=0}^n i^2 = \frac{(n^2+n)(2n+1)}{6}
These big equations seen very complicated, but basic stuff seems quite straightforward:
P = I^2 *R
R=V/I
It also works inline e.g x^2\sqrt{y} which is $x^2\sqrt{y}$
The plugin uses MathJax, which I believe is very similar to Latex. I donât have any experience or familiarly with writing maths!
Yay! Thanks, works great.
It takes a little bit to get used to. But this is the standard way to write math everywhere. MathJax supports most of the âstandardâ math syntax in LaTeX.
A few tips:
Nice, thatâs a really useful tip. Thanks!
And if itâs only a square root that you need, the old faithful HTML entity √ gives you â.
I love it, thanks! I think Iâll have to edit some old posts to make use of that
your post triggered this request ![]()
