1- Does the timer setting over-rule the PV divert function? the attached picture shows solar generation at 10w but the charging at 9amps with the timer activated
2- Should service level be set to 1,2,or auto?
3- My PV array is on the garage and connected to a smaller sub board(in the garage) with openevse fed from here also, so i have (Type2) setup for the emonpi with CT1 to incoming main (positive side) from the house to the garage sub board and CT2 to feed from sub board to inverter (positive side) this means i am not montioring the main house useage only the garage which is minimal, i can move the emonpi to the house and connect CT1 to incoming (grid) main and CT2 to feed to garage sub board, this would monitor all house useage but would have garage usage subtracted from PV generation and this would include any openevse charging which would knockout all PV generation does the openevse allow for this before calculating the divert level
