I am trying to send data from my emonhub setup (that resides on an OrangePi that just only that) to my recently installed EmonCMS on Ubuntu.
When it tries to send I get this in the emonhub log
2019-09-13 19:19:21,774 INFO emonCMS77 sending: http://192.168.7.77/emoncms/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1568398761.13,10,621,0,0,
0,24731,715,646,443,635,527,457,850,252,0]]&sentat=1568398761
2019-09-13 19:19:21,784 WARNING emonCMS77 couldn't send to server, HTTPError: 406
2019-09-13 19:19:21,785 WARNING emonCMS77 send failure: wanted 'ok' but got ''
In the emoncms log I see an attempt to do the update but it is rejected with a 406 (ignore the timestamps).
2019-09-13 18:19:28.857|INFO|index.php|emoncms/input/bulk.json
2019-09-13 18:19:28.860|WARN|index.php|406 Not Acceptable|emoncms/input/bulk
From an SSH on the emonhub machine, I can copy the curl example from the Inputs API and it works fine and appears as an input.
root@OrPi1:~# curl --data "node=1&data={power1:100,power2:200,power3:300}&apikey=93197a8e5f82273c2622d077xxxxxxxx" "http://192.168.7.77/input/post"
ok[1]- Exit 127 http://192.168.7.77/input/post?node=emontx
[2]+ Done fulljson={%22power1%22:100,%22power2%22:200,%22power3%22:300}
root@OrPi1:~# curl --data "node=1&data={power1:100,power2:200,power3:300}&apikey=93197a8e5f82273c2622d077xxxxxxx" "http://192.168.7.77/input/post"
This emonhub is quite happily communicating with my main EmonCMS setup - the only difference is the IP address (& API - yes I have checked) on the second reporter.
I have used this emonhub previously to report to 2 different instances so I know it has worked before.
The only place I can see that 406 Not Acceptable is here
