3D-printed covers for outside pipe clamps
Had my heat pump for about a month now. Decided before they had even finished installing that I didn’t like the metal pipe clips, so I 3d modelled and printed little clip covers for them:
They are nothing fancy, don’t require tools or additional hardware, they just slip over the existing clips with a snug fit.
The file is on makerworld if you want to print your own: https://makerworld.com/en/models/3711174-heat-pump-pipe-clamp-cover-68-74-mm#profileId-4265238
Before the clips:
