240VAC to 12VAC Transformers
I use one of these on my emonTX running the 3 phase sketch but don’t have access to a two channel scope to check the actual phase difference between the 240V and 9V sides.
If someone can suggest a method of comparing primary and secondary sides with a single channel scope I can certainly give it a go and report the results.
