Updating system libraries used by emoncms
While we are at it…
Can we please start installing the extensions using the provided mechanism rather than manually creating multiple text files?
all the OEM guides say to add 2 links for each extension/module in the apache2/conf.d and cli/conf.d folders under either etc/php5 or etc/php/7.0 depending on which version of php you are using. eg
sudo sh -c 'echo "extension=redis.so" > /etc/php/7.0/apache2/conf.d/20-redis.ini'
sudo sh -c 'echo "extension=redis.so" > /etc/php/7.0/cli/conf.d/20-redis.ini'
This is not in keeping with the intended methods, there should be only one text file written to the mods-available directory eg
echo 'extension=redis.so' > /etc/php/7.0/mods-available/redis.ini
and then the extension can be enabled with phpenmod redis or disabled with phpdismod redis eg
pb66@test2:~$ sudo phpenmod redis
pb66@test2:~$ ls -la /etc/php/7.0/*/conf.d/*redis.ini
lrwxrwxrwx 1 root root 37 Oct 27 12:54 /etc/php/7.0/apache2/conf.d/20-redis.ini -> /etc/php/7.0/mods-available/redis.ini
lrwxrwxrwx 1 root root 37 Oct 27 12:54 /etc/php/7.0/cli/conf.d/20-redis.ini -> /etc/php/7.0/mods-available/redis.ini
and
pb66@test2:~$ sudo phpdismod redis
ls: cannot access '/etc/php/7.0/*/conf.d/*redis.ini': No such file or directory
So instead of (for example)
for php5
sudo sh -c 'echo "extension=redis.so" > /etc/php5/apache2/conf.d/20-redis.ini'
sudo sh -c 'echo "extension=redis.so" > /etc/php5/cli/conf.d/20-redis.ini'
or for php 7.0
we would have
for php5
sudo sh -c 'echo "extension=redis.so" > /etc/php5/mods-available/redis.ini'
sudo php5enmod redis
or for php 7.0
sudo sh -c 'echo "extension=redis.so" > /etc/php/7.0/mods-available/redis.ini'
sudo phpenmod redis
or better still, since using echo for this purpose is frowned upon in many circles (since it behaves differently in various shell’s) and initiating another shell within a shell is messy (sudo sh -c) we should probably be using
for php5
printf "extension=redis.so" | sudo tee /etc/php5/mods-available/redis.ini 1>&2
or for php 7.0
printf "extension=redis.so" | sudo tee /etc/php/7.0/mods-available/redis.ini 1>&2
sudo phpenmod redis
I have been using these methods for a long time now without any issue.
