Unstable zero load value emontx shield
That’s what the calibration is for :relaxed:
The numbers we give you only work for one particular c.t. and one particular a.c. adapter, for anything else, our calibration will be wrong.
If you want the most accurate measurements, the full calibration procedure in at Learn→Electricity Monitoring→Current & Voltage→1. Calibration Procedure→Calibration Procedure
