Hello @nchaveiro and @TrystanLea
I made again a complete clean install on a spare Pi with the following information:
Server Information
| Services | ||
| emonhub | Active Running | |
| emoncms_mqtt | Active Running | |
| feedwriter | Active Running - sleep 60s | |
| service-runner | Active Running | |
| emonPiLCD | Active Exited | |
| redis-server | Active Running | |
| mosquitto | Active Running | |
| Emoncms | Version | low-write 9.9.8 |
| Modules | Administration : App v1.2.1 : Backup v1.1.6 : EmonHub Config v1.1.0 : Dashboard v1.3.3 : Device v1.2.1 : EventProcesses : Feed : Graph v1.2.3 : Input : Postprocess v1.0.0 : CoreProcess : Schedule : Network Setup v1.0.0 : sync : Time : User : Visualisation : WiFi v1.3.1 | |
| Git | URL: GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data : Branch: * stable : Describe: v9.5.1-1775-gd0db7a57 | |
| Server | OS | Linux 4.14.71-v7+ |
| Host | emonpi : emonpi : (192.168.2.241) | |
| Date | 2019-04-07 08:06:30 UTC | |
| Uptime | 08:06:30 up 21 min, 0 users, load average: 0.08, 0.05, 0.03 | |
| HTTP | Server | Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80 |
| MySQL | Version | 5.5.5-10.1.23-MariaDB-9+deb9u1 |
| Host | 127.0.0.1 (127.0.0.1) | |
| Date | 2019-04-07 08:06:29 (UTC 00:00) | |
| Stats | Uptime: 34289 Threads: 3 Questions: 550 Slow queries: 0 Opens: 24 Flush tables: 1 Open tables: 18 Queries per second avg: 0.016 | |
| Redis | Version | 3.2.6 |
| Host | localhost:6379 (127.0.0.1) | |
| Size | ||
| Uptime | 0 days | |
| MQTT Server | Version | Mosquitto 1.4.10 |
| Host | localhost:1883 (127.0.0.1) | |
| Pi | Model | Raspberry Pi 2 Model B Rev 1.1 - 1 GB (Sony UK) |
| SoC | Broadcom BCM2835 | |
| Serial num. | 67A92B68 | |
| Temperature | CPU: 34.70°C - GPU: 34.7’C | |
| Release | emonSD-30Oct18 | |
| Memory | RAM | Used: 14.81% Total: 976.74 MB Used: 144.66 MB Free: 832.08 MB |
| Swap | Used: 0.00% Total: 100 MB Used: 0 B Free: 100 MB | |
| Disk | Mount | Stats |
| / | Used: 39.87% Total: 3.81 GB Used: 1.52 GB Free: 2.11 GB | |
| /boot | Used: 51.69% Total: 42.52 MB Used: 21.98 MB Free: 20.54 MB | |
| /home/pi/data | Used: 3.44% Total: 3.21 GB Used: 112.81 MB Free: 2.93 GB | |
| PHP | Version | 7.0.30-0+deb9u1 (Zend Version 3.0.0) |
| Modules | apache2handler : calendar v7.0.30-0+deb9u1 : Core v7.0.30-0+deb9u1 : ctype v7.0.30-0+deb9u1 : curl v7.0.30-0+deb9u1 : date v7.0.30-0+deb9u1 : dom v20031129 : exif v7.0.30-0+deb9u1 : fileinfo v1.0.5 : filter v7.0.30-0+deb9u1 : ftp v7.0.30-0+deb9u1 : gd v7.0.30-0+deb9u1 : gettext v7.0.30-0+deb9u1 : hash v1.0 : iconv v7.0.30-0+deb9u1 : igbinary v2.0.1 : json v1.4.0 : libxml v7.0.30-0+deb9u1 : mbstring v7.0.30-0+deb9u1 : mcrypt v7.0.30-0+deb9u1 : mosquitto v0.4.0 : mysqli v7.0.30-0+deb9u1 : mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ : openssl v7.0.30-0+deb9u1 : pcre v7.0.30-0+deb9u1 : PDO v7.0.30-0+deb9u1 : pdo_mysql v7.0.30-0+deb9u1 : Phar v2.0.2 : posix v7.0.30-0+deb9u1 : readline v7.0.30-0+deb9u1 : redis v4.1.1 : Reflection v7.0.30-0+deb9u1 : session v7.0.30-0+deb9u1 : shmop v7.0.30-0+deb9u1 : SimpleXML v7.0.30-0+deb9u1 : sockets v7.0.30-0+deb9u1 : SPL v7.0.30-0+deb9u1 : standard v7.0.30-0+deb9u1 : sysvmsg v7.0.30-0+deb9u1 : sysvsem v7.0.30-0+deb9u1 : sysvshm v7.0.30-0+deb9u1 : tokenizer v7.0.30-0+deb9u1 : wddx v7.0.30-0+deb9u1 : xml v7.0.30-0+deb9u1 : xmlreader v7.0.30-0+deb9u1 : xmlwriter v7.0.30-0+deb9u1 : xsl v7.0.30-0+deb9u1 : Zend OPcache v7.0.30-0+deb9u1 : zlib v7.0.30-0+deb9u1 |
Client Information
| HTTP | Browser | Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:66.0) Gecko/20100101 Firefox/66.0 |
| Screen | Resolution | 1525 x 858 |
| Window | Size | 1506 x 730 |
Create the example standards physical inputs from API help, generate the the correspondent feeds. No customization made in the creation.
When try to create the virtual feed, with this feeds, the error occurs. I think in fact is a bug from the last update made by @TrystanLea, like you explain @nchaveiro.
Example of feeds add to make the virtual:
Apply the command:
It’s possible to correct this update @TrystanLea ?
Thanks for your attention and help.
