I’ve made a couple of further changes to the emon_DB_12CT firmware, feel free to upload this one now.
avrdb_firmware/emon_DB_12CT/emon_DB_12CT.ino at master · openenergymonitor/avrdb_firmware · GitHub
While I do have spare Pi Zero expansion PCB’s for the emonTx4 and Im more than happy to send you one, there were a couple of issues with that design that might make it more trouble than it’s worth. The Pi Zero needing a separate USB micro power supply being the main one as I made the mistake of not routing 5V to the expansion header.
How many temperature sensors do you need at the emonTx4 measurement point? The more straightforward solution is probably a USB powered EmonTH reading from multiple temperature sensors emonTH -Temperature & Humidity Node - Shop | OpenEnergyMonitor
The number of external temperature sensors can be specified in the firmware here emonth2/firmware/emonth2.ino at master · openenergymonitor/emonth2 · GitHub.
borpin
(Brian Orpin)
22
You could always wire that from the other header on the reverse side.
I think I will leave the TX4 alone and just add a PiZero with 1wire on the GPIO, then work out how to feed the values into EmonCMS.
I didn’t get to the FW last night I will have another run at it tomorrow and use the latest 12CT sketch.
borpin
(Brian Orpin)
24
Alternative is an ESP - I have several of these using Tasmota to do the job. Up to 6 sensors on each one.
Install emonhub (and just emonhub not emoncms) onto the Pi.
That’s much simpler, good idea! There are so many different ways to configure these things and sometimes a simpler solution like that is the best one. @borpin’s suggestion is also a good approach.
@whitecitadel I’ve updated the documentation page for the emonTx4 6 CT expansion board with reference to the new firmware, please see: 6 CT Expansion board — OpenEnergyMonitor 0.0.1 documentation
I’ve also updated the page for emonTx4 expansion boards in general to highlight what made it to production vs development only Expansion boards — OpenEnergyMonitor 0.0.1 documentation
I agree on the ESP but I could not find my spare ESP boards and I did find spare Pi Zero WiFi - thanks for the pointer on EmonHub not EmonCMS I will try that.
