+1
Has someone the final solution for syncing all the history data from EmonCMS.org to Local EmonCMS ?
I still can’t access the data synced using the Sync Module …
@JideyF you mention the feed sizes appear the same for local and remote feeds, do you see any data in the graph or is that when you see the error you mention?
Hi Tristan,
Now I think all is OK
What I did:
update Local EmonPi in Administration Tab
deleted all the inputs and feeds locally
started again a Sync with my eMonCMS.org account
I had to re-assign the Inputs to the Local Feeds in the Process Lists
I had to recreate the graphs
Then I had to re-assign the components on my different Dashboards to the local Feeds/Graphs
Now All is working Locally ! Great !!!
Many thanks !
Le ven. 21 sept. 2018 à 17:34, Trystan Lea [email protected] a écrit :
Great to hear!
2 posts were merged into an existing topic: Missing postprocess and sync menu entries emoncms 9.9.9
