Struggling to get good COP from Daikin 9kW
Back up heater
One more thing, consider turning off the back up heater:
The wisdom here is that we don’t typically need it in the UK. If you find your system is unable to heat your home or hot water during a cold snap, you would re-enable it. But it seems to come on more often than it should in normal operation, and is just a 3kW electric heater with a COP of 1.0.
There might be an argument that it helps the system get up to temperature more quickly, but most people here who are getting good efficiency have the BUH disabled.
