I think these are the latest FW versions for your unit
It worked fine. When the PWM signal starts up the pump uses that in preference to the speed selected by the button. The green LED also flashes slowly to indicate it is using PWM. When the PWM signal stops it reverts to the preset speed and the LEDs go back to as they were before PWMing
Yeah thatās the same as what Iāve found on my now installed UPM4. Except Iām sending the PWM signal from a standalone PWM controller as its still not working from Samsung controller.
Update - I was speaking to Samsung tech support before xmas and they think there is an issue with the PCB in the MIM-E03EN. They are sending me a replacement under warranty next week.
It seemed that while I was getting a PWM signla my voltage was 7.5V (low) and 12.1v (high). The low should be below 1v which is why the pump wasnāt kicking into PWM mode.
I will update again once Iāve replaced it.
