Receive zigbee sensor data on emonPi
Hi Glyn, I am confused as to where/how to access the zigbeemqtt frontend from the emonPi (as there is no browser installed). I have successfully set up a standalone RaspberryPi with zigbee2mqtt and am now trying to do the same on an emonPi, but stumped as to how to access the zigbeemqtt frontend.
Your help is greatly appreciated.
You should be able to access the front end on port 8080 either using hostname lookup which should work on most networks assuming there’s only one emonPi in the network http://emonpi.local:8080, or by replacing emonpi.local with the IP address of the emonpi e.g http://192.168.1.32:8080
You’ll need to be connected to the same local network as the emonPi
I’ve tried both emonpi.local:8080 and the IP address with the same result. Both the pi and my computer are on the same network. I can ssh into the pi without issue
I enabled the front end in the configuration.yaml file and it uses port 8080 by default.
Can you access the emonPi Emoncms interface on port 80? via http://emonpi.local or via the IP address?
If so, the issue must be with zigbee2mqtt. Try looking at the log files?
You could try making sure the port is open on the firewall with
sudo ufw allow 8080
I can access emonpi emoncms with http://emonpi.local and IP:80.
The command above did not resolve the issue.
So, back to zigbee2mqtt to find the issue.
thanks for the help.
I notice the MQTT section of the config you posted above should be using the localhost ip address i.e server: mqtt://127.0.0.1 if you want it to connect to the emonPi internal MQTT server
finally figured it out after looking at each character. I had an apostrophe (') in front of the 127.0.0.1 - always something stupid.
I am getting closer, but I am not seeing any inputs in emonCMS on the emonPi. It feels like I am missing a step. To avoid any confusion or potential conflicts, I am using an emonBase without any CT clamps, probes, or any 433Mhz devices attached. It is basically a RaspberryPi with the emon and zigbee2MQTT apps running.
One other thing. I could not get the Sonoff USB stick to work. So I switched to the ConBee II which shows up as /dev/ttyAMA0. This seems to work quite well. Does this create any conflict with emon?
I can connect to the Zigbee2MQTT dashboard and see my 3 test devices in the Zigbee dashboard.
I have made the changes to emonHub but do not see anything on the inputs page. I know that I am connected to MQTT in the emonhub log
    [[MQTT]]
        Type = EmonHubMqttInterfacer
        [[[init_settings]]]
            mqtt_host = 127.0.0.1
            mqtt_port = 1883
            mqtt_user = emonpi
            mqtt_passwd = emonpimqtt2016
        [[[runtimesettings]]]
           pubchannels = ToEmonCMS,
           node_JSON_enable = 1
           node_JSON_basetopic = zigbee2mqtt/temp1
From emonHub log
2024-08-11 23:09:40,456 INFO     MainThread EmonHub v2.5.5
2024-08-11 23:09:40,457 INFO     MainThread Opening hub...
2024-08-11 23:09:40,457 INFO     MainThread Running as user: pi
2024-08-11 23:09:40,457 INFO     MainThread Logging level set to DEBUG
2024-08-11 23:09:40,458 INFO     MainThread Creating EmonHubOEMInterfacer 'EmonPi2'
2024-08-11 23:09:40,458 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 115200 bits/s
2024-08-11 23:09:40,459 INFO     MainThread Creating EmonHubOEMInterfacer 'USB0'
2024-08-11 23:09:40,460 ERROR    MainThread Could not open serial port: /dev/ttyUSB0 @ 115200 bits/s (retry every 10s)
2024-08-11 23:09:40,460 INFO     MainThread Creating EmonHubRFM69LPLInterfacer 'SPI'
2024-08-11 23:09:40,461 ERROR    MainThread Unable to create 'SPI' interfacer: EmonHubRFM69LPLInterfacer.__init__() got an unexpected keyword argument 'resetPin'
2024-08-11 23:09:40,461 INFO     MainThread Creating EmonHubMqttInterfacer 'MQTT'
2024-08-11 23:09:40,461 DEBUG    MainThread Setting MQTT pubchannels: ['ToEmonCMS']
2024-08-11 23:09:40,462 INFO     MainThread Setting MQTT node_JSON_enable: 1
2024-08-11 23:09:40,462 INFO     MainThread Setting MQTT node_JSON_basetopic: zigbee2mqtt/temp1
2024-08-11 23:09:40,462 INFO     MQTT       Connecting to MQTT Server
2024-08-11 23:09:40,462 INFO     MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2024-08-11 23:09:40,464 DEBUG    MainThread Setting emoncmsorg interval: 30
2024-08-11 23:09:40,464 DEBUG    MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2024-08-11 23:09:40,464 DEBUG    MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2024-08-11 23:09:40,464 WARNING  MainThread Setting emoncmsorg apikey: obscured
2024-08-11 23:09:40,465 INFO     MainThread Setting emoncmsorg url: https://emoncms.org
2024-08-11 23:09:40,465 INFO     MainThread Setting emoncmsorg senddata: 1
2024-08-11 23:09:40,465 INFO     MainThread Setting emoncmsorg sendstatus: 0
2024-08-11 23:09:40,465 INFO     MainThread Setting emoncmsorg sendnames: 1
2024-08-11 23:09:40,465 INFO     MainThread Setting emoncmsorg compress: 0
2024-08-11 23:09:40,466 INFO     MainThread Creating EmonHubDS18B20Interfacer 'DS18B20'
2024-08-11 23:09:40,481 INFO     MainThread Setting DS18B20 read_interval: 10
2024-08-11 23:09:40,481 INFO     MainThread Setting DS18B20 nodename: sensors
2024-08-11 23:09:40,481 INFO     MainThread Setting DS18B20 ids:
2024-08-11 23:09:40,481 INFO     MainThread Setting DS18B20 names:
2024-08-11 23:09:40,482 DEBUG    MainThread Setting DS18B20 pubchannels: ['ToEmonCMS']
2024-08-11 23:09:40,482 DEBUG    MainThread Automatic configuration of nodes enabled
2024-08-11 23:09:40,565 INFO     MQTT       connection status: Connection successful
2024-08-11 23:09:40,565 INFO     MQTT       subscribe 1
2024-08-11 23:09:40,566 DEBUG    MQTT       CONACK => Return code: 0
2024-08-11 23:09:40,767 DEBUG    MQTT       on_subscribe
Nice work, have you switched to the mqtt_subscribe emonhub branch? This is needed to enable emonHub to subscribe to the JSON MQTT data, this has not yet been merged into emonhub master branch:
You can switch by mqtt_suscribe branch with
cd /opt/openenergymonitor/emonhub
git pull
git checkout mqtt_subscribe
You’ll need to add the following to emonhub.conf to get it to subscribe to a zigbee MQTT json topic:
[[MQTT_sub]]
    [[[init_settings]]]
        mqtt_port = 1883
        mqtt_user = emonpi
Replace temp with the name of your sensor. You can use MQTT Explorer to see what the MQTT data looks like on your emonPi.
Ahh. I figured I was missing a step. Will tackle this next.
I have 3 sensors. Do I configure like this?
node_JSON_enable = 3
And then
node_JSON_basetopic = zigbee2mqtt/aqi
node_JSON_basetopic = zigbee2mqtt/leak
Is the sensor name the same as “friendly name” used in zugbee2mqtt?
Thanks,
Gordon
I’m not sure about 3 sensors, I’ve only tested with one. Can you get one sensor working first? Then we can figure out how to add the other two.
You may need multiple instances of mqtt-sub e.g
[[MQTT_sub_temp]]
    [[[init_settings]]]
        mqtt_port = 1883
        mqtt_user = emonpi
[[MQTT_sub_aqi]]
    [[[init_settings]]]
        mqtt_port = 1883
        mqtt_user = emonpi
[[MQTT_sub_leak]]
    [[[init_settings]]]
        mqtt_port = 1883
        mqtt_user = emonpi
I’ve not tested this, so first try with one instance. Do you think this will work @TrystanLea ?
Sounds good. I will keep you updated.
Btw I never could get the Docket method to work so I used the Linux install method.
Hi Glyn,
I am subscribed to zigbeeMQTT topic (looks like I was already), but still do not see anything on the inputs screen of emonCMS. I think I am very close as I do see the data in the emonhub log. For some reason it is not creating the node on the emonCMS inputs screen.
2024-08-12 19:32:12,489 DEBUG    MQTT_sub   Received topic:zigbee2mqtt/Office Temp_Humid
2024-08-12 19:32:12,490 DEBUG    MQTT_sub   Received payload:{"battery":100,"humidity":45.1,"linkquality":255,"temperature":30}
2024-08-12 19:32:12,490 DEBUG    MQTT_sub   20 Sent to channel' : ToEmonCMS
2024-08-12 19:32:12,686 DEBUG    emoncmsorg Buffer size: 1
After making the changes below, I looked at the emonHub log and noticed a couple of error messages. I am unsure if they are applicable as the USB device I am using is showing up as serial port: /dev/ttyAMA0.
2024-08-12 19:11:49,099 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 115200 bits/s
2024-08-12 19:11:49,099 INFO     MainThread Creating EmonHubOEMInterfacer 'USB0'
2024-08-12 19:11:49,100 ERROR    MainThread Could not open serial port: /dev/ttyUSB0 @ 115200 bits/s (retry every 10s)
2024-08-12 19:11:49,101 INFO     MainThread Creating EmonHubRFM69LPLInterfacer 'SPI'
2024-08-12 19:11:49,101 ERROR    MainThread Unable to create 'SPI' interfacer: EmonHubRFM69LPLInterfacer.__init__() got an unexpected keyword argument 'resetPin'
And I have made the changes to emonHub as shown below.
  [[MQTT_sub]]
        [[[init_settings]]]
            mqtt_port = 1883
            mqtt_user = emonpi
           node_JSON_basetopic = zigbee2mqtt/Office Temp_Humid
When I look at the data being published, it is as shown below.
[2024-08-12 19:12:38] info:     z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"e132316","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x13415ff11ca3a005","panID":16128},"permit_join":true,"version":"1.39.1"}'
[2024-08-12 19:12:38] info:     z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Office Temp_Humid', payload '{"battery":100,"humidity":46.1,"linkquality":255,"temperature":30}'
[2024-08-12 19:12:38] info:     z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Office Air Quality', payload '{"air_quality":"good","battery":100,"humidity":45.3,"linkquality":255,"temperature":29.9,"update":{"installed_version":262145,"latest_version":262145,"state":"idle"},"update_available":false,"voc":549,"voltage":3100}'
[2024-08-12 19:12:38] info:     z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Office Water Leak', payload '{"battery":94}'
Lastly, here is the full log from lemon
2024-08-12 19:28:59,192 INFO     MainThread Creating EmonHubRFM69LPLInterfacer 'SPI'
2024-08-12 19:28:59,193 ERROR    MainThread Unable to create 'SPI' interfacer: EmonHubRFM69LPLInterfacer.__init__() got an unexpected keyword argument 'resetPin'
2024-08-12 19:28:59,194 INFO     MainThread Setting MQTT_sub node_JSON_basetopic: zigbee2mqtt/Office Temp_Humid
2024-08-12 19:28:59,194 INFO     MainThread Setting emoncmsorg senddata: 1
2024-08-12 19:28:59,194 INFO     MainThread Setting emoncmsorg sendnames: 1
2024-08-12 19:28:59,195 INFO     MainThread Setting DS18B20 read_interval: 10
2024-08-12 19:29:06,767 DEBUG    MainThread Signal 15 received.
2024-08-12 19:29:06,842 INFO     MainThread Exiting hub...
2024-08-12 19:29:07,081 INFO     MainThread Exit completed
2024-08-12 19:29:07,687 INFO     MainThread EmonHub v2.5.5
2024-08-12 19:29:07,687 INFO     MainThread Opening hub...
2024-08-12 19:29:07,687 INFO     MainThread Running as user: pi
2024-08-12 19:29:07,688 INFO     MainThread Logging level set to DEBUG
2024-08-12 19:29:07,688 INFO     MainThread Creating EmonHubOEMInterfacer 'EmonPi2'
2024-08-12 19:29:07,689 DEBUG    MainThread Opening serial port: /dev/ttyAMA0 @ 115200 bits/s
2024-08-12 19:29:07,689 INFO     MainThread Creating EmonHubOEMInterfacer 'USB0'
2024-08-12 19:29:07,690 ERROR    MainThread Could not open serial port: /dev/ttyUSB0 @ 115200 bits/s (retry every 10s)
2024-08-12 19:29:07,691 INFO     MainThread Creating EmonHubRFM69LPLInterfacer 'SPI'
2024-08-12 19:29:07,691 ERROR    MainThread Unable to create 'SPI' interfacer: EmonHubRFM69LPLInterfacer.__init__() got an unexpected keyword argument 'resetPin'
2024-08-12 19:29:07,691 INFO     MainThread Creating EmonHubMqttInterfacer 'MQTT_sub'
2024-08-12 19:29:07,692 DEBUG    MainThread Setting MQTT_sub pubchannels: ['ToEmonCMS']
2024-08-12 19:29:07,692 INFO     MainThread Setting MQTT_sub node_JSON_enable: 1
2024-08-12 19:29:07,692 INFO     MainThread Setting MQTT_sub node_JSON_basetopic: zigbee2mqtt/Office Temp_Humid
2024-08-12 19:29:07,692 INFO     MQTT_sub   Connecting to MQTT Server
2024-08-12 19:29:07,692 INFO     MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2024-08-12 19:29:07,694 DEBUG    MainThread Setting emoncmsorg interval: 30
2024-08-12 19:29:07,694 DEBUG    MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2024-08-12 19:29:07,694 DEBUG    MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2024-08-12 19:29:07,694 WARNING  MainThread Setting emoncmsorg apikey: obscured
2024-08-12 19:29:07,695 INFO     MainThread Setting emoncmsorg url: https://emoncms.org
2024-08-12 19:29:07,695 INFO     MainThread Setting emoncmsorg senddata: 1
2024-08-12 19:29:07,695 INFO     MainThread Setting emoncmsorg sendstatus: 0
2024-08-12 19:29:07,695 INFO     MainThread Setting emoncmsorg sendnames: 1
2024-08-12 19:29:07,695 INFO     MainThread Setting emoncmsorg compress: 0
2024-08-12 19:29:07,696 INFO     MainThread Creating EmonHubDS18B20Interfacer 'DS18B20'
2024-08-12 19:29:07,711 INFO     MainThread Setting DS18B20 read_interval: 10
2024-08-12 19:29:07,712 INFO     MainThread Setting DS18B20 nodename: sensors
2024-08-12 19:29:07,712 INFO     MainThread Setting DS18B20 ids:
2024-08-12 19:29:07,712 INFO     MainThread Setting DS18B20 names:
2024-08-12 19:29:07,712 DEBUG    MainThread Setting DS18B20 pubchannels: ['ToEmonCMS']
2024-08-12 19:29:07,713 DEBUG    MainThread Automatic configuration of nodes enabled
2024-08-12 19:29:07,795 INFO     MQTT_sub   connection status: Connection successful
2024-08-12 19:29:07,795 INFO     MQTT_sub   subscribe 1
2024-08-12 19:29:07,796 DEBUG    MQTT_sub   CONACK => Return code: 0
2024-08-12 19:29:07,996 DEBUG    MQTT_sub   on_subscribe
2024-08-12 19:34:06,714 DEBUG    MQTT_sub   Received topic:zigbee2mqtt/Office Temp_Humid
2024-08-12 19:34:06,714 DEBUG    MQTT_sub   Received payload:{"battery":100,"humidity":45.1,"linkquality":255,"temperature":30}
2024-08-12 19:34:06,715 DEBUG    MQTT_sub   32 Sent to channel' : ToEmonCMS
2024-08-12 19:34:06,945 DEBUG    emoncmsorg Buffer size: 1
That’s great, it looks like emonhub is successfully subscribing to the zigbee data. I’m not sure why Inputs are nor being created. Are you able to give me remote access? I could try and take a look?
The error Could not open serial port: /dev/ttyUSB0 is because there must be an emonub interfacer trying to connect to a serial device on USB0, but there’s no device connected. You can remove this interfacer to get rid of this error.
Have you got an RFM69 device connected? If not, remove the SPI interfacer from emonHub, this will fix the error. Unable to create 'SPI' interfacer: EmonHubRFM69LPLInterfacer.__init__() got an unexpected keyword argument 'resetPin' remove
Yes, this will conflict on an emonPi2 with the internal serial port. But it will work fine, on a emonBase as long as the emonPi2 interfacer is removed which will by trying to connect on ttyAMA0
Should I delete this section in emonhub to remove the error?
   [[USB0]]
        Type = EmonHubOEMInterfacer
        [[[init_settings]]]
            com_port = /dev/ttyUSB0
            com_baud = 115200
            subchannels = ToRFM12,
            nodename = emonTx4
I do not have a RFM69 device so I will delete this section.
How would you like to access remotely?
Also, I’m planning on using a RaspberryPi Zero for this application not the emonPi2.
Glyn, I set up port forwarding so you can remote in. I will send you the info in PM.
yes
Ok great. I only need SSH, no need for HTTP
@glyn.hudson @TrystanLea
Hi Trystan and Glyn,
Is there a way to manually add inputs?
As mentioned, I am seeing the data in emonhub
2024-08-15 16:23:30,893 DEBUG    MQTT_sub   Received topic:zigbee2mqtt/Office Air Quality
2024-08-15 16:23:30,894 DEBUG    MQTT_sub   Received payload:{"air_quality":"excellent","battery":100,"humidity":35.9,"linkquality":255,"temperature":30.7,"update":{"installed_version":262145,"latest_version":262145,"state":"idle"},"update_available":false,"voc":221,"voltage":3100}
2024-08-15 16:23:30,894 DEBUG    MQTT_sub   15320 Sent to channel' : ToEmonCMS
2024-08-15 16:23:43,239 DEBUG    emoncmsorg Buffer size: 1
And below are the entries in emonhub config
    [[MQTT_sub]]
        [[[init_settings]]]
            mqtt_port = 1883
            mqtt_user = emonpi
           node_JSON_basetopic = zigbee2mqtt/Office Air Quality
But the Inputs screen is blank
I am at a loss trying to determine how to create the inputs. Please advise.
Thank you,
Gordon
Ok, I’ve had a look at your system and the only thing I can see is that your JSON payload being published by zigbee2mqtt has got two nested JSON items:
{"air_quality":"excellent","battery":100,"humidity":34.3,"linkquality":255,"temperature":32,"update":{"installed_version":262145,"latest_version":262145,"state":"idle"},"update_available":false,"voc":59,"voltage":3100}
While my payload when I tested it was:
{"battery":100,"humidity":80,"temperature":22,"voltage":3100}
Also, your JSON payload contains text values instead of numerical e.g "air_quality":"excellent"
Supporting nested payloads will require dev work on emonhub and Emoncms only supports numerical inputs, I’m afraid I don’t have the time to spend on this now. Zigbee is not something that we officially support.
