Raspberry Pi 4
Correct! Sorry! It was a typo. What i wanted to write was on boot folder.
I created a empty file named ssh and copy to the boot folder but i ended up always getting a connection refused when ssh the rpi 4. And the file was still there. Don’t know why it didn’t worked.
OS: Linux 4.19.57-v7l+
Host: emonpi | emonpi | (192.168.1.80)
Date: 2019-07-14 16:00:31 CEST
Uptime: 15:00:32 up 1 min, 1 user, load average: 1.33, 0.63, 0.24
Missing Pi info:
Try “ssh” ie all lower case.
Ok. I don’t have much time these days but i will test.
Should i change to stable branch or should stay as it is?
Just a small note: this pi releases more heat. It would be wise to test it under the emonpi case to see if temperatures rise even more. Yesterday, when connecting it to my monitor and keyboard, it was really hot.
I confirm it was on lower case.
I had to enter in desktop mode, going to preferences and activate the ssh mode.
I will stay for now with this image since i want to install node-red to see if is stable. After that, i will buy a SSD, install the rpi on my emonpi and will make it boot on the ssd.
Then i will test again if ssh file works ok.
EDIT: ( edited the above post to the correct filename)
To swap the Emonpi RPI and install the rpi 4, does the pins that connect to other components change or are the same?
Are something that i should be aware?
Can i connect as it was on the older Pi?
EDIT 1: This pi 4 (4GB version that i have) it has a huge improvement in speed. The pi 3 took me 30 min downloading and installing node-red and the pi 4 took 5 min!
EDIT 2: Here is my update log.
LAST ENTRIES ON THE LOG FILE
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-30Oct18
emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
* buster
No ramo buster
Your branch is up to date with 'origin/buster'.
não há nada para submeter, árvore de trabalho limpa
Already up to date.
Main Update Script
Date: dom jul 14 16:50:45 WEST 2019
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: all
firmware: emonpi
Hardware detected: rfm2pi
git pull /opt/openenergymonitor/emonpi
* master
No ramo master
Your branch is up to date with 'origin/master'.
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
No ramo master
Already up to date.
EmonPi Firmware Update
Start ATmega328 serial upload using avrdude with latest.hex
Discrete Sampling
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex
avrdude-original: Using autoreset DTR on GPIO Pin 7
avrdude-original: stk500_recv(): programmer is not responding
avrdude-original: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude-original done. Thank you.
strace: |autoreset: Broken pipe
Start emonhub update script:
emonHub update
git pull /opt/openenergymonitor/emonhub
* emon-pi
No ramo emon-pi
Your branch is up to date with 'origin/emon-pi'.
Already up to date.
Failed to restart .service.service: Unit .service.service not found.
- Service
Start emoncms update:
Update Emoncms Core
current settings.php md5: af198c0ef59536b35ab37f07d1f0a718
Default settings.php md5: 0e4803a641b7784ed23edf87506ce761
settings.php HAS been user modified
Checking status of /var/www/emoncms git repository
- git branch: master
- no local changes
- running: git pull origin master
De https://github.com/emoncms/emoncms
* branch master -> FETCH_HEAD
fc77f92e..bc06fc04 master -> origin/master
A atualizar fc77f92e..bc06fc04
Fast-forward
Theme/basic/svg_icons.php | 173 +++++++++++++++++++++++++++++++++++++++++++++
Theme/basic/theme.php | 176 +---------------------------------------------
index.php | 2 +-
3 files changed, 177 insertions(+), 174 deletions(-)
create mode 100644 Theme/basic/svg_icons.php
NEW default settings.php md5: 0e4803a641b7784ed23edf87506ce761
settings.php not updated
Update Emoncms database
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 2.0.1-7-gd897495
- no local changes
Already up to date.
Já em 'master'
Updating /var/www/emoncms/Modules/config module
- git tags: 2.0.2
- no local changes
Already up to date.
Já em 'master'
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 2.0.3-4-gcae18c3
- no local changes
Already up to date.
Já em 'master'
Updating /var/www/emoncms/Modules/device module
- git tags: 2.0.0-4-g7dd5c26
- no local changes
Already up to date.
Já em 'master'
Updating /var/www/emoncms/Modules/graph module
- git tags: 2.0.1-2-gc069436
- no local changes
Already up to date.
Já em 'master'
Updating /var/www/emoncms/Modules/wifi module
- git tags: 2.0.0-14-g3d07646
- no local changes
Already up to date.
Já em 'master'
Updating /opt/emoncms/modules/backup module
- git tags: 2.0.0-14-g83893ac
- no local changes
Already up to date.
Já em 'master'
Updating /opt/emoncms/modules/demandshaper module
- git tags: 1.1-1-gc8f4a22
- no local changes
Already up to date.
Já em 'master'
Updating /opt/emoncms/modules/postprocess module
- git branch: emonpi
- git tags: 2.1.0-3-g558173e
- no local changes
- running: git pull origin emonpi
Already up to date.
Já em 'emonpi'
Your branch is up to date with 'origin/emonpi'.
Updating /opt/emoncms/modules/sync module
- git tags: 2.0.1-11-ge7dcf33
- no local changes
Already up to date.
Já em 'master'
Updating /opt/emoncms/modules/usefulscripts module
fatal: Nenhum nome encontrado, não é possível descrever.
- git tags:
- no local changes
Already up to date.
Já em 'master'
emonPi update done: dom jul 14 16:51:58 WEST 2019
restarting service-runner
Some words are in portuguese. Probably because this is the desktop version.
Thanks!
That’s a thought, I think Glyn applied a modification to underclock the pi’s on the emonSD image, I dont think I put that on the build script yet. There are also a few items such as the memory tweak that I havent yet tested or applied EmonScripts/install/emonsd.sh at master · openenergymonitor/EmonScripts · GitHub
Hi everybody,
just a short question: are there any plans to update the documentation to include clear instructions for installing emoncms on the Pi 4 ?
Thanks!
Regards,
Hello @Romeo yes, once the build script reaches a full release (its currently in alpha for early testers) we will update the documentation and highlight what systems it is compatible with.
I’ve merged the generic php installation process into the master branch of the EmonScripts repository:
Merge pull request #10 from openenergymonitor/development · openenergymonitor/EmonScripts@4209fd4 · GitHub
It seems to be working fine along with the removal of opcache and mcrypt
Update php.sh · openenergymonitor/EmonScripts@dda7495 · GitHub
This means that there is now the one master branch for the Pi4 and Pi3.
I also tested building the image on Buster using the Pi4 and then swapping the SD card over to a Pi3 B+ which seemed to work fine.
Wifi AP and client are also working now.
As far as I can make out, you haven’t swapped the serial port mapping with an overlay either. A couple of points on that (although I’m now thinking this should probably be discussed in the emonScripts thread?), firstly the overlay currently used on the emonSD disables BT rather than swapping the serial ports around to keep BT functionality, however as far as I can make out, by enabling the serial port with uart_enable=1 in config.txt and using the default serial mapping (ie just disable the serial console, not the serial port and do not use a custom overlay) then the clock speed is reduced and fixed at 250kHz to stabilise the serial port, effectively under-clocking the processor slightly, but more importantly disabling the “turbo” type boosts. So rather than swap the serial ports around and underclocking as well, if we just use the ports as originally mapped (and disable serial console as we must already) it should be simpler (and run cooler?) without losing BT.
There was a new release of Buster Raspbian on the 10th July. So I hope we’re all using that now?
Thanks @pb66 Im not that familiar with those settings, they where additions by @glyn.hudson, Il make a note to discuss with Glyn, do you think you could create it as an issue on the EmonScripts repository?
My latest test was with the latest Buster image: 2019-07-10-raspbian-buster-lite.zip
