emonPi/base update now includes updating emonhub to python3!
The update process includes the installation of Python3 and dependencies as well as a call to apt-get update which can take a little time on slower connections.
The emonPiLCD script and service-runner are still ran with Python 2.7 which remains on the system.
To be better safe than sorry I’ve pushed a fix that passed the $emonSD_pi_env variable to the install script as argument 1, I realise the install script is actually looking for this and then skips the user entry skip user entry · openenergymonitor/EmonScripts@6e3d2b7 · GitHub
Attempted to use the python3 version of emonhub and the EmonHubSocketInterfacer.py.
I get this error on packet receipt.
2020-06-10 17:10:39,183 WARNING Pulse Exception caught in Pulse thread. Traceback (most recent call last):
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 32, in wrapper
return f(*args)
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 99, in run
rxc = self.read()
File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubSocketInterfacer.py", line 69, in read
select.select([self._socket], [], [], 0)
TypeError: argument must be an int, or have a fileno() method.
I note that there is a print f which I corrected but I am getting this error with Python3
File "/home/pi/pulses.py", line 31, in eventHandler2
processpulse(2,GPIO.input(channel))
File "/home/pi/pulses.py", line 51, in processpulse
send(f)
File "/home/pi/pulses.py", line 58, in send
s.send(f)
TypeError: a bytes-like object is required, not 'str'
I’m not sure I fully understand the architecture here. Is emonhub running on a pi with a pulse counter (well, photodiode) connected to its own GPIO pins?
If that’s the case then this should be quite simple, since emonhub will handle all the network stuff, we just need to give it the appropriate packets at the right time.
Happy to chuck something together if someone can explain the hardware setup.
Sorry. Where I’d like to end up is that the Pi with emonhub running has the pulse counter connected to the GPIO pins and there is an emonhub Pulse interfacer to read that data and load it into a frame for the rest of emonhub to do it’s stuff (other thread really).
The socket thing will probably not be needed for this, it is just the reading of the pins.
However, in trying to test this, I used the linked script on a Pi without emonhub - so effectively I’m testing the socket interfacer on Python3 which possibly has not been tested.
I have 2 problems with this, one the script didn’t want to play for Python3 and secondly the socket interfacer on the other Pi with emonhub didn’t want to play.
2 issues on the emonhub side,
it seems the nb_port works when the default is used, but not if a port is specified in the [[initsettings]]
Are there any log messages associated with that socket error? If the initialisation of the socket fails, the code continues as if nothing is wrong, except for logging an error, so then it explodes later when it tries to use it.
Nice work finding those bugs, I agree that a .decode() is needed there.
It looks like the set() method of doesn’t understand the port_nb setting. Not sure if that’s the cause of your first problem.
Just what I posted. Results in TypeError: argument must be an int, or have a fileno() method. as though the open_socket call did not return an integer. I did think a debug message saying socket opened might help!
This topic is getting a bit diverse, maybe @borpin can work some thread-splitting magic?
With encouragement and help from @alexandrecuer I have had a go at upgrading emonPiLCD to python3. To encourage people to pull it, I added some new features, like being able to gather the temperature and other things from the new MQTT topics, rather than the legacy “values” topic. Also, it now displays a neat little degree symbol!
You will need to install python3-xmltodict, and perhaps other things, but the install/update scripts scare me so I’ll leave the upgrade to someone who understands that better.
on the emonPi I was using to test your fork…did a git pull and a sudo reboot : the LCD did not want to reboot by itself…I had to poweroff manually the Pi…Since that it seems to work fine…
EDIT : after a reboot, the LCD detects the sensors, boots the PI, but remains illuminated on a blue screen without displaying anything
Anyway, it appears the service file is running correctly :
pi@emonpi:~ $ sudo systemctl status emonPiLCD.service
● emonPiLCD.service - emonPi LCD driver
Loaded: loaded (/lib/systemd/system/emonPiLCD.service; enabled; vendor preset
Active: active (running) since Thu 2020-06-18 11:25:03 CEST; 4min 42s ago
Main PID: 935 (python3)
Tasks: 5 (limit: 2319)
Memory: 11.5M
CGroup: /system.slice/emonPiLCD.service
└─935 /usr/bin/python3 /opt/openenergymonitor/emonpi/lcd/emonPiLCD.py
Jun 18 11:25:03 emonpi systemd[1]: Started emonPi LCD driver.
In addition to the actions related to the scripts, I have installed the following dependencies:
