Click to view Octopus API specific-day backfill Node-RED flow code
"id": "dda3a2d6.12063",
"type": "tab",
"label": "Octopus Agile Specific Day",
"disabled": false,
"info": ""
"id": "731abbac.7c1e84",
"type": "http request",
"z": "dda3a2d6.12063",
"name": "Octopus API http-request",
"method": "GET",
"ret": "obj",
"paytoqs": "ignore",
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "basic",
"x": 230,
"y": 220,
"wires": [
"5be2a24d.fb9ccc",
"4656ec43.52e5f4"
"id": "2e3bf84d.b0e6c8",
"type": "inject",
"name": "Trigger",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "00 08 * * *",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 120,
"y": 100,
"wires": [
"eb641d81.0f7dc"
"id": "eb641d81.0f7dc",
"type": "function",
"name": "Build Octopus API URL",
"func": "var newmsg = {};\n\nvar host = \"https://api.octopus.energy/v1\";\nvar mpan = \"YOUR_MPAN_HERE\";\nvar meter = \"YOUR_METER_NUM_HERE\";\n\nnewmsg.url = host;\nnewmsg.url += \"/electricity-meter-points/\" + mpan;\nnewmsg.url += \"/meters/\" + meter;\nnewmsg.url += \"/consumption\";\nnewmsg.url += \"?period_from=2020-10-03T23:30Z\";\nnewmsg.url += \"&period_to=2020-10-04T23:30Z\";\nnewmsg.url += \"&order_by=period\";\n\nreturn newmsg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 190,
"y": 160,
"wires": [
"731abbac.7c1e84"
"id": "962d3ef1.417c7",
"type": "comment",
"name": "Instructions for use",
"info": "### First-time Preparation\n\n1 - Modify the 'Build Octopus API URL' function node with your meter details (MPAN and meter number). \n\n2 - Input your Octopus APIKey into the Username field in the 'Octopus API http-request node. Leave password blank.\n\n3 - Modify the 'Backfill data to chosen period' node with your EmonCMS write API key, and the feed id number of the feed you are backfilling data to (this step is crucial to get correct, or the new data you fetch could wreck a different feed than intended!!). \nYou can determine your chosen feed's correct ID number by viewing it in a Graph display - it'll be listed at the bottom panel where the colours and charting features are selected, preceding the feed name.\n\n4 - Also in the 'Backfill data to chosen period' node, change the hostname of the newmsg.url, so that it points to your local EmonCMS installation correctly. (NB. May work with emonCMS.org, but currently untested. Use at your own risk!)\n\n### Performing a 'run'\n\n1 - in the 'Build Octopus API URL' node, set the 'period_from' and 'period_to' items correctly. Best to just change the year/month/day parts accordingly; the current time settings will fetch what Octopus generally considers 'day-end' and 'day-start' limits, and handle (ignore) any ongoing daylight-savings in force at the time.\n\n2 - Select any debug nodes you wish to view/suppress, according to your taste.\n\n3 - Deploy the NodeRed Flow!\n\n4 - Press the button on the Trigger node to begin the run.\n\n",
"x": 310,
"y": 40,
"wires": []
"id": "5be2a24d.fb9ccc",
"type": "debug",
"name": "Octopus return-data debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 520,
"y": 220,
"wires": []
"id": "4656ec43.52e5f4",
"type": "function",
"name": "Backfill data to chosen period",
"func": "var apikey = \"YOUR_EMONCMS_WRITE_KEY\"; //your EmonCMS write APIkey\nvar feedid = YOUR_FEED_ID; //change this to the correct Feed ID!!\nvar host = \"http://YOUR_EMONCMS_HOST\"; //your local EmonCMS server address\n\nvar fetchedarr = msg.payload.results;\nfetchedarr.forEach(dataParse);\n\nfunction dataParse(item,index,arr) {\n\n var newmsg = {};\n \n newmsg.payload = {};\n newmsg.payload.apikey = apikey;\n newmsg.payload.id = feedid; \n newmsg.payload.time = Date.parse(arr[index].interval_start)/1000;\n newmsg.payload.value = arr[index].consumption;\n newmsg.payload.skipbuffer = 1; //what does this do??\n \n newmsg.url = host + \"/feed/update.json\";\n \n node.send(newmsg);\n}",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"x": 260,
"y": 280,
"wires": [
"2aa7f578.b6f46a"
"id": "78b2d951.0095d8",
"name": "send to EmonCMS",
"method": "GET",
"ret": "txt",
"paytoqs": "query",
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 270,
"y": 400,
"wires": [
"5e8837bd.9fe058"
"id": "2aa7f578.b6f46a",
"type": "delay",
"name": "",
"pauseType": "rate",
"timeout": "5",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "2",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"x": 240,
"y": 340,
"wires": [
"78b2d951.0095d8",
"e8e5e44f.eee338"
"id": "5e8837bd.9fe058",
"type": "debug",
"name": "emoncms debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"x": 530,
"y": 400,
"wires": []
"id": "e8e5e44f.eee338",
"type": "debug",
"name": "backfill data debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 530,
"y": 340,
"wires": []
