PVOutput.org NodeRed
Yes, yes I did, after much head scratching, I learnt enough JS/Node Red to be dangerous. Though I’m posting it to PVO as well as EmonCMS, as the full history of my PV system is on PVO.
So, I’ve coded up a working solution to push data from EmonSD/Node Red to PVO, and it’s been running for about 5 months. It’s hit several problems, similar to my PERL version, but seems to be working fine now. I’ve been meaning to play with GitHub and get it posted up but been too busy with other stuff.
Have a play…
PVOutput.txt (19.1 KB)
The only important thing is you will need to insert your API key/sys id into the two nodes mentioned.
You will also need to tweak or remove the temperature nodes at the bottom to pick up the right ones or not.
Then it should just go. Good luck!
If not, I’ll be around… :grinning:
