Brian,
Thank you, I made the change you suggested but it didn’t stop the error messages every 5 seconds in the emoncms.log.
Looking at the emonhub.log, it seems the string of data isn’t from MQTT but “RFM2Pi.” Does this seem correct to you? Thanks. Bob
2024-11-18 09:48:30,241 DEBUG    RFM2Pi     733 NEW FRAME : OK 8 200 0 180 0 35 1 60 0 87 43 178 0 188 0 49 1 245 0 184 11 184 11 184 41 0 0 (-28)
2024-11-18 09:48:30,243 DEBUG    RFM2Pi     733 Timestamp : 1731941310.240966
2024-11-18 09:48:30,244 DEBUG    RFM2Pi     733 From Node : 8
2024-11-18 09:48:30,245 DEBUG    RFM2Pi     733    Values : [427.52, 384.768, 291, 60, 122.204768, 17.8, 18.8, 30.5, 24.5, 300, 300, 10680]
2024-11-18 09:48:30,246 DEBUG    RFM2Pi     733      RSSI : -28
2024-11-18 09:48:30,246 DEBUG    RFM2Pi     733 Sent to channel(start)' : ToEmonCMS
2024-11-18 09:48:30,247 DEBUG    RFM2Pi     733 Sent to channel(end)' : ToEmonCMS
2024-11-18 09:48:30,438 DEBUG    MQTT       Publishing: emon/emontx3/power1 427.52
2024-11-18 09:48:30,438 DEBUG    MQTT       Publishing: emon/emontx3/power2 384.768
2024-11-18 09:48:30,439 DEBUG    MQTT       Publishing: emon/emontx3/power3 291
2024-11-18 09:48:30,439 DEBUG    MQTT       Publishing: emon/emontx3/power4 60
2024-11-18 09:48:30,439 DEBUG    MQTT       Publishing: emon/emontx3/vrms 122.204768
2024-11-18 09:48:30,440 DEBUG    MQTT       Publishing: emon/emontx3/temp1 17.8
2024-11-18 09:48:30,440 DEBUG    MQTT       Publishing: emon/emontx3/temp2 18.8
2024-11-18 09:48:30,440 DEBUG    MQTT       Publishing: emon/emontx3/temp3 30.5
2024-11-18 09:48:30,446 DEBUG    MQTT       Publishing: emon/emontx3/temp4 24.5
2024-11-18 09:48:30,446 DEBUG    MQTT       Publishing: emon/emontx3/temp5 300
2024-11-18 09:48:30,447 DEBUG    MQTT       Publishing: emon/emontx3/temp6 300
2024-11-18 09:48:30,447 DEBUG    MQTT       Publishing: emon/emontx3/pulse 10680
2024-11-18 09:48:30,448 DEBUG    MQTT       Publishing: emon/emontx3/rssi -28
2024-11-18 09:48:40,183 DEBUG    RFM2Pi     734 NEW FRAME : OK 8 217 0 176 0 30 1 58 0 82 43 178 0 188 0 49 1 245 0 184 11 184 11 184 41 0 0 (-27)
2024-11-18 09:48:40,185 DEBUG    RFM2Pi     734 Timestamp : 1731941320.183510
2024-11-18 09:48:40,186 DEBUG    RFM2Pi     734 From Node : 8
2024-11-18 09:48:40,187 DEBUG    RFM2Pi     734    Values : [463.8592, 376.2176, 286, 58, 122.149696, 17.8, 18.8, 30.5, 24.5, 300, 300, 10680]
2024-11-18 09:48:40,187 DEBUG    RFM2Pi     734      RSSI : -27
2024-11-18 09:48:40,188 DEBUG    RFM2Pi     734 Sent to channel(start)' : ToEmonCMS
2024-11-18 09:48:40,188 DEBUG    RFM2Pi     734 Sent to channel(end)' : ToEmonCMS
2024-11-18 09:48:40,280 DEBUG    MQTT       Publishing: emon/emontx3/power1 463.8592
2024-11-18 09:48:40,282 DEBUG    MQTT       Publishing: emon/emontx3/power2 376.2176
2024-11-18 09:48:40,283 DEBUG    MQTT       Publishing: emon/emontx3/power3 286
2024-11-18 09:48:40,284 DEBUG    MQTT       Publishing: emon/emontx3/power4 58
2024-11-18 09:48:40,285 DEBUG    MQTT       Publishing: emon/emontx3/vrms 122.149696
2024-11-18 09:48:40,286 DEBUG    MQTT       Publishing: emon/emontx3/temp1 17.8
2024-11-18 09:48:40,287 DEBUG    MQTT       Publishing: emon/emontx3/temp2 18.8
2024-11-18 09:48:40,288 DEBUG    MQTT       Publishing: emon/emontx3/temp3 30.5
2024-11-18 09:48:40,289 DEBUG    MQTT       Publishing: emon/emontx3/temp4 24.5
2024-11-18 09:48:40,290 DEBUG    MQTT       Publishing: emon/emontx3/temp5 300
2024-11-18 09:48:40,291 DEBUG    MQTT       Publishing: emon/emontx3/temp6 300
2024-11-18 09:48:40,292 DEBUG    MQTT       Publishing: emon/emontx3/pulse 10680
2024-11-18 09:48:40,294 DEBUG    MQTT       Publishing: emon/emontx3/rssi -27
2024-11-18 09:48:50,023 DEBUG    RFM2Pi     735 NEW FRAME : OK 8 201 0 174 0 28 1 58 0 90 43 178 0 188 0 47 1 245 0 184 11 184 11 184 41 0 0 (-28)
2024-11-18 09:48:50,024 DEBUG    RFM2Pi     735 Timestamp : 1731941330.022798
2024-11-18 09:48:50,025 DEBUG    RFM2Pi     735 From Node : 8
2024-11-18 09:48:50,025 DEBUG    RFM2Pi     735    Values : [429.6576, 371.94239999999996, 284, 58, 122.23781120000001, 17.8, 18.8, 30.3, 24.5, 300, 300, 10680]
2024-11-18 09:48:50,026 DEBUG    RFM2Pi     735      RSSI : -28
2024-11-18 09:48:50,027 DEBUG    RFM2Pi     735 Sent to channel(start)' : ToEmonCMS
2024-11-18 09:48:50,027 DEBUG    RFM2Pi     735 Sent to channel(end)' : ToEmonCMS
2024-11-18 09:48:50,130 DEBUG    MQTT       Publishing: emon/emontx3/power1 429.6576
2024-11-18 09:48:50,131 DEBUG    MQTT       Publishing: emon/emontx3/power2 371.94239999999996
2024-11-18 09:48:50,132 DEBUG    MQTT       Publishing: emon/emontx3/power3 284
2024-11-18 09:48:50,133 DEBUG    MQTT       Publishing: emon/emontx3/power4 58
2024-11-18 09:48:50,134 DEBUG    MQTT       Publishing: emon/emontx3/vrms 122.23781120000001
2024-11-18 09:48:50,135 DEBUG    MQTT       Publishing: emon/emontx3/temp1 17.8
2024-11-18 09:48:50,136 DEBUG    MQTT       Publishing: emon/emontx3/temp2 18.8
2024-11-18 09:48:50,137 DEBUG    MQTT       Publishing: emon/emontx3/temp3 30.3
2024-11-18 09:48:50,138 DEBUG    MQTT       Publishing: emon/emontx3/temp4 24.5
2024-11-18 09:48:50,139 DEBUG    MQTT       Publishing: emon/emontx3/temp5 300
2024-11-18 09:48:50,140 DEBUG    MQTT       Publishing: emon/emontx3/temp6 300
2024-11-18 09:48:50,141 DEBUG    MQTT       Publishing: emon/emontx3/pulse 10680
2024-11-18 09:48:50,142 DEBUG    MQTT       Publishing: emon/emontx3/rssi -28
shows your error messages happening every 5 s ± 6 ms.
The post immediately above shows an emonTx V3 reporting every 9.9 s. It’s not that.
