Powerwall API help
I’m pretty sure the split is working too, but and the key is being written to a parts set. But I’m not having much luck accessing it!
Screenshot from 2020-04-02 17-58-02
HA!
Having a Boris Grishenko moment.
(Massive HT to @borpin for all the help).
So, by changing the change node - it works! I dropped the Powerwall group and set it to msg instead of string.
Screenshot from 2020-04-02 18-15-55
Flow below:
[{"id":"6f4bec9.6832c94","type":"tab","label":"Flow 2"},{"id":"fbb0563f.73c548","type":"split","z":"6f4bec9.6832c94","name":"","splt":"\\n","x":436,"y":151,"wires":[["a7db7a95.7f59f"]]},{"id":"2aa0a68.a63aeda","type":"http request","z":"6f4bec9.6832c94","name":"aggregates","method":"GET","ret":"obj","url":"https://192.168.1.220/api/meters/aggregates","tls":"2ef5995c.70f58e","x":278,"y":88,"wires":[["fbb0563f.73c548"]]},{"id":"9daec9b2.76ac4","type":"emoncms","z":"6f4bec9.6832c94","name":"emoncms","emonServer":"5243d6fc.b657f","nodegroup":"","datatype":"fulljson","x":813,"y":174,"wires":[]},{"id":"a7db7a95.7f59f","type":"change","z":"6f4bec9.6832c94","name":"","rules":[{"t":"move","p":"payload.last_communication_time","pt":"msg","to":"time","tot":"msg"},{"t":"set","p":"nodegroup","pt":"msg","to":"parts.key","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":638,"y":94,"wires":[["9daec9b2.76ac4"]]},{"id":"53d70381.4a29a4","type":"inject","z":"6f4bec9.6832c94","name":"","topic":"","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"x":105,"y":35,"wires":[["2aa0a68.a63aeda"]]},{"id":"2ef5995c.70f58e","type":"tls-config","z":"","name":"","cert":"","key":"","ca":"./data/powerwall.pem","verifyservercert":false},{"id":"5243d6fc.b657f","type":"emoncms-server","z":"","server":"http://192.168.1.161/emoncms","name":"emonpi"}]
Now I can log my use, powerwall and solar without needing to fit CT clips inside my breaker box (thanks installers for hiding all the single core wiring - in their defence I didn’t ask them to leave any out for me).
Hi @miker; I copied & Imported your flow, but having changed the url in the aggregates node to match my network, & adding my emonPi details in the emoncms node I am getting two errors.
In the aggregates node unable_to_verify_leaf_signature
In the emoncms node API Failed RC=200
Are these easily resolved?
TIA
PS Might it be because I told it to use an emoncms “node” of pw2 without actually setting one up?
Because the data sent is not valid - i.e. it includes the error text.
Did you search before asking the question? The answer is often there.
@haffle you may not need to CA cert. I never tested it without, but there is an option to ignore the CA cert, even when the CA cert is enabled.
The powerwall cert is self signed, so it’s not secure at all. Personally I don’t understand why Tesla bothered!
Thanks @miker - I managed to get it to work in the end. :+1:
Good stuff!
Hello, to all the Powerwall API Helpers – I would appreciate some help / guidance please.
We have a Powerwall2 so I’ve been attempting to distil the earlier information for my set up which is different on several counts:
a) I’m using a desktop PC running Linux Mint 19.1 Cinnamon 64-bit instead of a Rpi.
b) I’m using emoncms.org instead of a local version.
My objective is to to see the battery state of charge on the dashboard along with the existing power use graphics for the house.
Progress to date (after a lot of reading along with a lot more trial and error): Node-red has been successfully installed via the command line. I’m able to access and use http://127.0.0.1:1880/ and the required emoncms flow nodes have been installed.
My flow initially comprised: ‘timestamp’ Node wired to a ‘http request’ Node which is wired to a ‘debug’ Node. The verify server certificate option associated with the ‘Edit http request node’ (Edit tis-config node) was not ticked and the ‘Return’ was set up as ‘a parsed JASON object’. At this point I feel things are working OK as the debug message provides ‘msg:payload : object’ with the battery charge every 10 seconds.
An ‘emoncms’ Node was added as the next stage and wired to receive data from the ‘http request’ Node. A ping to the emoncms.org server provided its IP address. This was used for setting up the ‘Edit Emoncms-server Node’ along with the Emoncms API key (read).
Whilst the debug message continues to provide the battery charge every 10 seconds another message now appears from ‘node : emoncms’. Changing the ‘Data Type to: ‘Legacy Processing’ / ‘Valid JSON Object’ / ‘Simple JSON’ does not eliminate this error message:
30/06/2020, 16:28:55node: Emoncms
msg : Object
{ topic: “http response”, payload: “<!doctype html>↵↵↵…”, _msgid: “1f11b4ba.72c53b”, statusCode: 200, headers: object … }
N.B. This is the text message which has appeared beneath the emoncms Node: API Failed RC=406
All offers to help will be gratefully received. But, that said, please remember it will be necessary to provide such help, or requests for additional information, in ‘BBC Bite Size Chunks’ due to my inexperience.
TIA Michael
Don’t use the IP address - just use emoncms.org.
JSON object, not the bloke.
So you need to copy the error msg object and paste the whole thing. It should appear in the debug sidebar. If not put a Catch-all node in your flow and connect it to a debug node.
Also put a debug note on the flow passing data to the emoncms node to see what you are passing in the payload.
If you mouse over the messages on the right, you will see ‘copy value’.
When you paste the values here put 3 backticks (top left of keyboard) on a line before and 3 on a line after.
code
Thanks for taking the time to help.
Done.
Finger trouble when writing - it is correct in the ‘Return’
{"topic":"http response","payload":"<!doctype html>\n<html>\n<head>\n    <meta http-equiv=\"content-type\" content=\"text/html; charset=UTF-8\">\n    <meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">\n    <title>Emoncms - emoncms.org input post</title>\n    <link rel=\"shortcut icon\" href=\"http://109.169.55.159/Theme/basic/favicon.png\" />\n    <meta name=\"apple-mobile-web-app-capable\" content=\"yes\">\n    <meta name=\"apple-mobile-web-app-status-bar-style\" content=\"black\">\n    <link rel=\"apple-touch-startup-image\" href=\"http://109.169.55.159/Theme/basic/ios_load.png\">\n    <link rel=\"apple-touch-icon\" href=\"http://109.169.55.159/Theme/basic/logo_normal.png\">\n\n    <link href=\"http://109.169.55.159/Lib/bootstrap/css/bootstrap.min.css\" rel=\"stylesheet\">\n    <link href=\"http://109.169.55.159/Lib/bootstrap/css/bootstrap-responsive.min.css\" rel=\"stylesheet\">\n    <link href=\"http://109.169.55.159/Theme/basic/emoncms-base.css?v=11\" rel=\"stylesheet\">\n    <link href=\"http://109.169.55.159/Theme/basic/emon-blue.css?v=11\" rel=\"...","_msgid":"ed1bf0de.95e75","statusCode":200,"headers":{"cache-control":"no-store","content-type":"application/json","date":"Tue, 30 Jun 2020 20:40:59 GMT","content-length":"32","connection":"close","x-node-red-request-node":"6aa730ac"},"responseUrl":"https://192.168.1.13/api/system_status/soe","redirectList":[],"urlsent":"http:/109.169.55.159/emoncms.org/input/post?fulljson={\"percentage\":49.77711738484398}&node=0&apikey=xxx…….xxx","rc":406,"warning":"ERROR: API Call Failed"}
msg.payload : Object
{ percentage: 49.508243118941486 }
I’m not sure that emoncms.org handles JSON (@TrystanLea).
If you change to legacy processing and make the payload you send to the emoncms node just the number, it might work.
I never tested it with emoncms.org to be honest. I should.
Yes it does, only state of charge figures and no error messages.
Thanks again for your help.
