Good news you’ve found the issue.
I can if needed add the ability to use the same mqtt topic for booth shaper/divert grid mode
Does it has any sense ? Not using divert here so I’m not used to it.
You can try to use an esp32 with external antenna like the esp32CAM if you don’t want to hack your module
