waako
(Tom Bamford)
10
Thanks @TrystanLea ,
Yes, I am running stable branch with emonSD setup, and emoncms/input/list.json gives me:
Fatal error: Call to a member function fetch_object() on boolean in /var/www/emoncms/Modules/input/input_model.php on line 377
I notice this error came up in Emoncms Apps: Call to a member function fetch_object() on a non-object? But I’ve tried running database updates, but they don’t stick and have this issue on the page:
Notice: Trying to get property of non-object in /var/www/emoncms/Lib/dbschemasetup.php on line 41
The logs were indeed being filled by Node Red’s telegram node, removed it and logs issue fixed, I’d already moved to using chatbot anyway.
I’m guessing it had something to do with node-red-contrib-telegrambot wanting NodeJS version 5.x and I’m on 4.8. Although unsure why it suddenly became a problem.
