pb66
(Paul)
15
To add further to the existing notes. today I set up a gas meter monitor using a hall sensor, I had assigned it a node ID of 30 and the payload currently contains just 2 unsigned longs, pulse count and uptime in milliseconds. Immediately after powering it up I saw the packets arriving at both my own emoncms and emoncms.org, this comes from a forwarding only read-only Pi running (original) emonHub so additional configuration isn’t mandatory. So far so good!
However! when I checked the emonPi, it was receiving ok and forwarding to emoncms.org ok too, but nothing was being seen at the emonpi/emoncms inputs page except for RSSI. Recalling the numeric node id was probably to blame, I set up an entry in emonhub.conf as
[nodes]
[[30]]
nodename = GasMon
[[[rx]]]
names = GasUnits, Uptime
datacode = L
scales = 0.01, 0.001
units = m3, Secs
This changed the node name from “Node 30” to “GasMon” on the inputs page but did not show any of the inputs, still only RSSI was present. working on the idea of Redis being a factor, I decided to “Flush Redis” from the admin page. At which point all the other inputs ceased to update any longer, the emonPi, emonTx and 2 emonTH’s all stopped updating, I waited sometime and kept refreshing the page with no sign of any updates. Checked emonhub (via emoncms) and could see the data being published ok. So I rebooted (from the admin page) and after the reboot all was well, all my existing nodes were updating and the “GasMon” was properly created and updating.
I have since tried “Flush Redis” again, twice and neither time did it stop the inputs updating. I will if I get a chance create another new node at some point and re-enact what I have done here again, but on the surface it looks like creating a new node (without a pre-existing emonhub.conf entry) not only doesn’t get created on the inputs page, but it also causes a problem for Redis that cannot be Flushed and at the very least requires a reboot to even recognize the new node.
