I will get on this now and make the changes to the code. Should have an updated version to test shortly.
@TrystanLea I have just submitted a PR
Please test it first if you use it as I was unable to test.
Thanks again @pb66, tested here, with a minor modification to the connection
self._sdm = sdm_modbus.SDM120(device=device, baud=int(baud))
it worked fine.
I will have a look at improving the options to name the parameters.
I’ve added a prefix option which makes the sdm_ part optional.
[[SDM120]]
Type = EmonHubSDM120Interfacer
[[[init_settings]]]
device = /dev/ttyUSB0
baud = 2400
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
read_interval = 10
nodename = SDM120
# prefix = sdm_
In the code there is an array that defines the SDM120 key’s to read, short names and number of decimal points to round the value too:
read_keys = {
'voltage':('V',2),
'power_active':('P',2),
'power_factor':('PF',4),
'frequency':('FR',4),
'import_energy_active':('E',3),
'current':('I',3)
The parameters are then read if present in the data returned from the SDM120:
for i in read_keys:
if i in r:
c.names.append(self._settings['prefix']+read_keys[i][0])
c.realdata.append(round(r[i],read_keys[i][1]))
The prefix is blank by default so inputs will appear under nodename SDM120, input names: V,P,PF etc.
My own use case is posting the SDM120 data alongside MBUS data under a single nodename called heatpumpmonitor and so the prefix is useful so that I can then set the inputs to be: heatpumpmonitor:sdm_V etc…
@srt these recent updates are still in the emonhub master branch for now. With a bit more testing I will merge them into stable and do a release. For now would you mind switching to this branch to test the new changes?
The steps are (via SSH):
cd /opt/openenergymonitor/emonhub
git checkout master
git pull
As @srt has modified some of the files, he will need to get rid of the changes by checking out that file first else Git will complain.
One thing, I think it is bad form to drop experimental stuff into master - it should really go into a dev branch first IMHO, merged to master for final testing and then released as stable.
You have told me many times @borpin I think there are too many steps, perhaps we should just have stable and development for the main branches… I do leave features in a specific feature branch when they are really experimental but try and bring them into master at least when they dont break anything else, even if the feature itself in this case the SDM120 reader is a very early version of the feature. I just find things go stale very quickly if left in feature branches for wider testing. I know I’m not going to get agreement on this.
Edit: I think @srt is the first person to use this in 2 months? or at least post an issue…
Why have you opted for hardcoded names albeit with a prefix rather than using the existing practice of using [nodes] definitions? “Voltage” is obviously more user friendly than “sdm_v” or just “v” especially as there is no way to change the names in emoncms if you want data via mqtt?
There is no reason you couldn’t have a default array of names eg sdm_v, sdm_p, etc and let users define their own array. Likewise for precision levels.
Although the oem emonhub follows the emonhub-wide [nodes] definitions I am veering towards interfacer level node definitions so rather than a [nodes] definition you could easily have names = voltage,power_active
etc and precision = 2,2,4
etc in the interfacer [[runtimesettings]].
However, I personally would prefer to see users able to define any number of the available values in any order so they can create thier own node formats eg
values = power_active, voltage
names = Power, MainsVoltage
precision = 2, 1
would give a node of 2 values, “Power” first to 0.01 units (I assume Watts?) and MainsVoltage to 0.1 volts. This might not have much effect on “status” type MQTT but when frames of data are posted via http (and hopefully MQTT too) you can select the order the inputs are read and processed, very important when using more than one input in a calculation during processing.
@pb66 true that could work fine, so the values setting would define the SDM120 parameter order to map to names and precision… is values the best name for this?
Whilst I don’t disaggree with what you say, the naming of the branches is what causes the confusion, ordinarily development is done in another branch eg “dev” and merged to “master” after final testing, only after a release has seen the test of time could it be called “stable” so really oem stable = master and oem master = dev since master is usually where the releases come from not from “stable” as is the case with oem.
Ha Ha!
Yes naming is crucial, eg above eg rfm12pi (with rfm69 module) or emoncms id/name name/desc etc, not our strongest point, ay?
I’m not fixed on “values” it possibly isn’t right but it needs to be generic so that all interfacers can reuse without issue (for example using “interval” rather than “read_interval”), I was just floating the concept as I really don’t like hardcoded elements so IF changes were being made I hoped this would approach could be considered.
I first used this approach for the wunderground interfacer even before emonhub experimental branch.
[edit - just looked to see what I used back then]
Currently available datafields are “temp_c”, “feelslike_c”, “dewpoint_c”, “heat_index_c”, “windchill_c”, “wind_mph”, “wind_gust_mph”, “visibility_mi”, “precip_1hr_metric”, “precip_today_metric”, “UV”, “wind_degrees”, “pressure_mb”, “pressure_in”, “pressure_trend”, “relative_humidity”, “temp_f”, “feelslike_f”, “dewpoint_f”, “heat_index_f”, “windchill_f”, “wind_kph”, “wind_gust_kph”, “visibility_km”, “precip_1hr_in”, “precip_today_in”
Which any number can be strung together as csv, in any order to create a frame be passed to emoncms eg
datafields = relative_humidity, feelslike_c, pressure_mb
I think datafields works well, it’s generic and clear.
Agreed and that is how I think it should be.
The risk is, merging directly to master, if someone is running master and using SDM120 and decides to do an update while all this is going on, they could easily break their system and wonder why!
Before doing anything, I take a branch off master and update that branch. You can then easily merge to master once it all works. Of course I cannot merge directly anyway .
they should be aware they are using the oem equivalent of a staging dev branch.
The only issue (aside from the names) is that (IMO) the repo’s should use/display the stable branch by default and only hotfixes PR’d to that repo, features and rewrites go from a feature branch to master (aka dev).
Yes I agree that would help ensure most people use the stable branch, the current arrangement does encourage the use of master for those installing manually
OK, so I:
a) flipped the A/B terminals on the RS485/USB converter (I can see me doing this again…)
b)applied your git pull
c)restarted emonhub
emonhub runs, but there doesn’t seem to be any SDM data.
disclaimer: I have played a bit with RPi and python in the past, but it’s few and far between, so while I can ssh and execute commands, I really have no idea what I’m doing. And a little knowledge is a dangerous thing - so best treat me like an idiot. Meanwhile, here’s a chunk of log:
2021-01-21 16:13:20,583 INFO MainThread Exiting hub...
2021-01-21 16:13:32,335 INFO MainThread Exit completed
2021-01-21 16:13:34,897 INFO MainThread EmonHub emonHub (emon-pi variant) v2.1.5
2021-01-21 16:13:34,898 INFO MainThread Opening hub...
2021-01-21 16:13:34,899 INFO MainThread Logging level set to DEBUG
2021-01-21 16:13:34,900 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2021-01-21 16:13:34,902 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2021-01-21 16:13:36,910 INFO MainThread RFM2Pi device firmware version & configuration: not available
2021-01-21 16:13:36,911 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2021-01-21 16:13:37,913 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2021-01-21 16:13:38,916 INFO MainThread Setting RFM2Pi group: 210 (210g)
2021-01-21 16:13:39,918 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2021-01-21 16:13:40,920 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2021-01-21 16:13:41,923 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2021-01-21 16:13:41,924 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2021-01-21 16:13:41,927 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2021-01-21 16:13:41,932 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-21 16:13:41,933 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2021-01-21 16:13:41,935 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2021-01-21 16:13:41,936 INFO MainThread Setting MQTT node_format_enable: 1
2021-01-21 16:13:41,937 INFO MainThread Setting MQTT nodevar_format_enable: 1
2021-01-21 16:13:41,938 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2021-01-21 16:13:41,939 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2021-01-21 16:13:41,941 DEBUG MainThread Setting emoncmsorg pubchannels: ['ToRFM12']
2021-01-21 16:13:41,942 DEBUG MainThread Setting emoncmsorg subchannels: ['ToEmonCMS']
2021-01-21 16:13:41,943 WARNING MainThread Setting emoncmsorg apikey: obscured
2021-01-21 16:13:41,943 INFO MainThread Setting emoncmsorg url: https://emoncms.org
2021-01-21 16:13:41,944 INFO MainThread Setting emoncmsorg senddata: 1
2021-01-21 16:13:41,944 INFO MainThread Setting emoncmsorg sendstatus: 1
2021-01-21 16:13:41,946 INFO MainThread Creating EmonHubSDM120Interfacer 'SDM120'
2021-01-21 16:13:41,958 INFO MainThread Connecting to SDM120 device=/dev/ttyUSB0 baud=2400
2021-01-21 16:13:41,961 INFO MainThread Setting SDM120 read_interval: 10
2021-01-21 16:13:41,962 INFO MainThread Setting SDM120 nodename: SDM120
2021-01-21 16:13:41,962 INFO MainThread Setting SDM120 prefix:
2021-01-21 16:13:41,963 DEBUG MainThread Setting SDM120 pubchannels: ['ToEmonCMS']
2021-01-21 16:13:42,037 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-21 16:13:42,141 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-21 16:13:42,249 DEBUG RFM2Pi 1 NEW FRAME : OK 5 238 252 232 255 214 252 2 93 0 0 0 0 0 0 0 0 0 0 0 0 249 224 0 0 (-0)
2021-01-21 16:13:42,252 DEBUG RFM2Pi 1 Timestamp : 1611245622.249539
2021-01-21 16:13:42,253 DEBUG RFM2Pi 1 From Node : 5
2021-01-21 16:13:42,253 DEBUG RFM2Pi 1 Values : [-786, -24, -810, 238.1, 0, 0, 0, 0, 0, 0, 57593]
2021-01-21 16:13:42,254 DEBUG RFM2Pi 1 Sent to channel(start)' : ToEmonCMS
2021-01-21 16:13:42,254 DEBUG RFM2Pi 1 Sent to channel(end)' : ToEmonCMS
2021-01-21 16:13:42,358 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-21 16:13:42,441 INFO MQTT Connecting to MQTT Server
2021-01-21 16:13:42,462 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz q1 USA 0
2021-01-21 16:13:42,545 INFO MQTT connection status: Connection successful
2021-01-21 16:13:42,546 DEBUG MQTT CONACK => Return code: 0
2021-01-21 16:13:42,557 DEBUG emoncmsorg Buffer size: 1
2021-01-21 16:13:42,648 INFO MQTT on_subscribe
2021-01-21 16:13:44,688 DEBUG RFM2Pi 2 NEW FRAME : OK 5 234 252 233 255 211 252 36 93 0 0 0 0 0 0 0 0 0 0 0 0 252 224 0 0 (-0)
2021-01-21 16:13:44,690 DEBUG RFM2Pi 2 Timestamp : 1611245624.688024
2021-01-21 16:13:44,691 DEBUG RFM2Pi 2 From Node : 5
2021-01-21 16:13:44,691 DEBUG RFM2Pi 2 Values : [-790, -23, -813, 238.44, 0, 0, 0, 0, 0, 0, 57596]
2021-01-21 16:13:44,692 DEBUG RFM2Pi 2 Sent to channel(start)' : ToEmonCMS
2021-01-21 16:13:44,693 DEBUG RFM2Pi 2 Sent to channel(end)' : ToEmonCMS
2021-01-21 16:13:44,964 DEBUG MQTT Publishing: emon/emonpi/power1 -790
2021-01-21 16:13:44,966 DEBUG MQTT Publishing: emon/emonpi/power2 -23
2021-01-21 16:13:44,968 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -813
2021-01-21 16:13:44,970 DEBUG MQTT Publishing: emon/emonpi/vrms 238.44
2021-01-21 16:13:44,972 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-21 16:13:44,974 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-21 16:13:44,976 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-21 16:13:44,978 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-21 16:13:44,979 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-21 16:13:44,981 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-21 16:13:44,982 DEBUG MQTT Publishing: emon/emonpi/pulsecount 57596
2021-01-21 16:13:44,984 INFO MQTT Publishing 'node' formatted msg
2021-01-21 16:13:44,984 DEBUG MQTT Publishing: emonhub/rx/5/values -790,-23,-813,238.44,0,0,0,0,0,0,57596
2021-01-21 16:13:49,642 DEBUG RFM2Pi 3 NEW FRAME : OK 5 234 252 233 255 211 252 44 93 0 0 0 0 0 0 0 0 0 0 0 0 0 225 0 0 (-0)
2021-01-21 16:13:49,645 DEBUG RFM2Pi 3 Timestamp : 1611245629.642466
2021-01-21 16:13:49,645 DEBUG RFM2Pi 3 From Node : 5
2021-01-21 16:13:49,646 DEBUG RFM2Pi 3 Values : [-790, -23, -813, 238.52, 0, 0, 0, 0, 0, 0, 57600]
2021-01-21 16:13:49,647 DEBUG RFM2Pi 3 Sent to channel(start)' : ToEmonCMS
2021-01-21 16:13:49,647 DEBUG RFM2Pi 3 Sent to channel(end)' : ToEmonCMS
2021-01-21 16:13:49,757 DEBUG MQTT Publishing: emon/emonpi/power1 -790
2021-01-21 16:13:49,758 DEBUG MQTT Publishing: emon/emonpi/power2 -23
2021-01-21 16:13:49,760 DEBUG MQTT Publishing: emon/emonpi/power1pluspower2 -813
2021-01-21 16:13:49,761 DEBUG MQTT Publishing: emon/emonpi/vrms 238.52
2021-01-21 16:13:49,762 DEBUG MQTT Publishing: emon/emonpi/t1 0
2021-01-21 16:13:49,764 DEBUG MQTT Publishing: emon/emonpi/t2 0
2021-01-21 16:13:49,765 DEBUG MQTT Publishing: emon/emonpi/t3 0
2021-01-21 16:13:49,766 DEBUG MQTT Publishing: emon/emonpi/t4 0
2021-01-21 16:13:49,768 DEBUG MQTT Publishing: emon/emonpi/t5 0
2021-01-21 16:13:49,769 DEBUG MQTT Publishing: emon/emonpi/t6 0
2021-01-21 16:13:49,771 DEBUG MQTT Publishing: emon/emonpi/pulsecount 57600
2021-01-21 16:13:49,772 INFO MQTT Publishing 'node' formatted msg
2021-01-21 16:13:49,773 DEBUG MQTT Publishing: emonhub/rx/5/values -790,-23,-813,238.52,0,0,0,0,0,0,57600
2021-01-21 16:13:53,877 DEBUG RFM2Pi 5 NEW FRAME : OK 23 56 0 0 0 158 3 31 0 1 0 0 0 (-65)
2021-01-21 16:13:53,880 DEBUG RFM2Pi 5 Timestamp : 1611245633.877559
2021-01-21 16:13:53,881 DEBUG RFM2Pi 5 From Node : 23
2021-01-21 16:13:53,881 DEBUG RFM2Pi 5 Values : [5.6000000000000005, 0, 92.60000000000001, 3.1, 1]
2021-01-21 16:13:53,882 DEBUG RFM2Pi 5 RSSI : -65
2021-01-21 16:13:53,882 DEBUG RFM2Pi 5 Sent to channel(start)' : ToEmonCMS
2021-01-21 16:13:53,883 DEBUG RFM2Pi 5 Sent to channel(end)' : ToEmonCMS
2021-01-21 16:13:54,114 DEBUG MQTT Publishing: emon/emonth5/temperature 5.6000000000000005
2021-01-21 16:13:54,115 DEBUG MQTT Publishing: emon/emonth5/external temperature 0
2021-01-21 16:13:54,117 DEBUG MQTT Publishing: emon/emonth5/humidity 92.60000000000001
2021-01-21 16:13:54,118 DEBUG MQTT Publishing: emon/emonth5/battery 3.1
2021-01-21 16:13:54,120 DEBUG MQTT Publishing: emon/emonth5/pulsecount 1
2021-01-21 16:13:54,121 DEBUG MQTT Publishing: emon/emonth5/rssi -65
2021-01-21 16:13:54,122 INFO MQTT Publishing 'node' formatted msg
2021-01-21 16:13:54,123 DEBUG MQTT Publishing: emonhub/rx/23/values 5.6000000000000005,0,92.60000000000001,3.1,1,-65
2021-01-21 16:13:54,693 DEBUG RFM2Pi 6 NEW FRAME : OK 5 234 252 231 255 209 252 25 93 0 0 0 0 0 0 0 0 0 0 0 0 3 225 0 0 (-0)
2021-01-21 16:13:54,695 DEBUG RFM2Pi 6 Timestamp : 1611245634.692925
You could try putting it back the other way, it is best to make changes one at a time. Although we did see the failure with the symlink in place so I’m not sure it will work.
@TrystanLea has also made some other changes since and the debug line that was previously being reached (but failing) is no longer there so we can’t easily compare
I think the issue might be in this bit as anywhere else leads to an error message or exception
for i in read_keys:
if i in r:
c.names.append(self._SDM120_settings['prefix']+read_keys[i][0])
comparing keys with strings?? I don’t know what the raw r
is like.
Thanks @srt, that’s a pain, I’m sure I remember seeing the key error voltage error in you earlier post before, but cant remember now how I solved it or what the reason was.
I have the latest code running and working well on my SDM120 here, so I dont think its that code necessarily.
You could try running this code manually @srt
import sdm_modbus, time
device = sdm_modbus.SDM120(device="/dev/ttyUSB0", baud=2400)
last_reading = 0
while True:
if (time.time()-last_reading)>=10.0:
last_reading = time.time()
if device.connected():
r = device.read_all(sdm_modbus.registerType.INPUT)
for i in r:
print(i+" "+str(r[i]))
# print ("%f %f %f %f %f" % (r['voltage'],r['power_active'],r['power_factor'],r['frequency'],r['import_energy_active']))
time.sleep(0.1)
Create a file called sdm120.py and copy the contents into that file:
nano sdm120.py (right click and then paste)
Run the script with:
python3 sdm120.py
You may need to stop emonhub first:
sudo service emonhub stop
