I would say that is good practice, I rewired some of our circuits eg the freezers have their own circuit so that I don’t come home to defrosted freezers because (say) the dishwasher has had a moment and tripped the kitchen ring main, plus I can monitor them separately and also control them, forcing them to run more during off-peak tariff periods by disconnecting the power during peak times if the temp remains low(ish).
I did say
There isn’t a simple dedicated “bus” for this, you would need to use a USB/rs485 adapter and either expand on the current emonhub “modbus” offering or write a custom script that polls your devices and posts the data, either via an emonhub socket, MQTT or HTTP. Can sound daunting but there’s a lot of help out there, I would certainly chip in. I have my own modbus interfacer in development and whilst I’m not at the stage to share just yet I have no issue with sharing concept’s or code snippets etc. My interfacer is aiming to be universal to all modbus devices, by either simple custom config options or by templates, I have a dozen or so devices templated and have had them all running at once on one bus, but other stuff has had priority lately, but this is a pet project that I would love to get back into.
No no jumpers, all the devices I have require the Id to be set via modbus so I have a little script that I use on a one to one basis with each new device to set a unique id before adding it to the bus.
I would say they are around the same size but as the meters are rail mounted they are much neater and since they are mounted they usually have a box, rather than leaving them hanging on exposed cables or cramming them into the CU. They are (IMO) much better for the same space used in that they are hardwired, revenue grade, neater etc for the same money/space, not because they are smaller/cheaper.
You can’t really mix breakers and meters easily as the busbar fingers get in the way of the meter conns. Yes you can cut them off but it’s still tight getting a cable into the meter, especially when it’s a short fat cable from the adjacent breaker, any chaffing of cable on sharp busbar finger remains, could short (bypass) the breaker if not careful.
You can use an unpopulated CU if you want the meters on display, I tend to prefer a simple box with top hat din rail at a depth that puts all the meter faces just below the lid face and allows any wiring to run behind/under it. Since you are reading the meters via modbus they needn’t be visible. The plain box lid is tidier and perhaps provides somewhere to put a schematic or legend or even some indicators or buttons etc should your system grow. Not to mention being cheaper to boot, so a big box to house all the gubbings is cheaper than a CU for just the meters.
“gubbings” = meters, din mounted Pi, din mounted 5v supply, din mounted relays etc?
