My solar app help
Hi all,
Hoping someone can help.
I setup a MySolar app using some feeds, then realised I had created a feed using the wrong engine so I deleted it and recreated it in the correct engine, now when I try to open the MySolar app I get an error saying correctly that a feed is missing but it then hangs so I can’t get the settings open to change it to the new existing feed also I can’t recreate the missing feed as new feeds won’t reuse old feed numbers.
Kind regards,
Matt
Hi Matt,
It’s probably best to manually remove the app and recreate it (you may need to replace emonpi with the IP address):
http://emonpi/app/remove?name=MySolar
Worked perfectly!
Many thanks.
