Note: The issue with copying the default settings file from the EmonScripts repo is that it contains key words that are replaced by the installation script so copying it over doesnt work unfortunately, the version of the settings file I have pasted above is the version that results after modification by the install script and is suitable for image emonSD-17Oct19
Thank you for the reply, I copied over the settings and now the input processing shows up correctly, the emonhub log is still empty and not running. I think its something to do with the update re flashing the rfm12
I tried to refresh it again but it gives broken pipe errors, is this ok ?
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-17Oct19
emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
nothing to commit, working tree clean
Already up to date.
Main Update Script
Date: Wed 8 Jul 12:22:47 BST 2020
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: firmware
firmware: rfm12pi
Hardware detected: rfm2pi
RFM12Pi Firmware Update
Flashing RFM12Pi
avrdude-original: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyAMA0
Using Programmer : arduino
Overriding Baud Rate : 38400
avrdude-original: Using autoreset DTR on GPIO Pin 7
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/opt/openenergymonitor/data/firmware/rfm12pi.hex"
avrdude-original: input file /opt/openenergymonitor/data/firmware/rfm12pi.hex auto detected as Intel Hex
avrdude-original: writing flash (8982 bytes):
Writing | ################################################## | 100% 3.08s
avrdude-original: 8982 bytes of flash written
avrdude-original: verifying flash memory against /opt/openenergymonitor/data/firmware/rfm12pi.hex:
avrdude-original: load data flash data from input file /opt/openenergymonitor/data/firmware/rfm12pi.hex:
avrdude-original: input file /opt/openenergymonitor/data/firmware/rfm12pi.hex contains 8982 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 2.79s
avrdude-original: verifying ...
avrdude-original: 8982 bytes of flash verified
strace: |autoreset: Broken pipe
avrdude-original done. Thank you.
Flashing RFM12Pi done
emonPi update done: Wed 8 Jul 12:23:01 BST 2020
LAST ENTRIES ON THE LOG FILE
master
* stable
On branch stable
Already up to date.
Main Update Script
Date: Wed 8 Jul 16:52:25 BST 2020
EUID: 1000
type: all
firmware: none
Running apt-get update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists...
git pull /opt/openenergymonitor/emonpi
* master
On branch master
Your branch is up to date with 'origin/master'.
Fetching origin
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
On branch master
Fetching origin
Already up to date.
Start emonhub update script:
emonHub update
git fetch --all --prune -v
Fetching origin
POST git-upload-pack (989 bytes)
From https://github.com/openenergymonitor/emonhub
a0cd518..d2c5dd3 stable -> origin/stable
= [up to date] MQTTSubscriberInterfacer -> origin/MQTTSubscriberInterfacer
= [up to date] SDS011 -> origin/SDS011
= [up to date] emon-pi -> origin/emon-pi
= [up to date] env_example -> origin/env_example
= [up to date] lanip-status -> origin/lanip-status
97581bc..1da8085 master -> origin/master
= [up to date] redis_config_interface -> origin/redis_config_interface
= [up to date] unitless_decoder -> origin/unitless_decoder
git status
On branch stable
Your branch is behind 'origin/stable' by 2 commits, and can be fast-forwarded.
(use "git pull" to update your local branch)
Untracked files:
(use "git add ..." to include in what will be committed)
src/src
nothing added to commit but untracked files present (use "git add" to track)
git pull origin stable
* branch stable -> FETCH_HEAD
Updating a0cd518..d2c5dd3
Fast-forward
src/interfacers/EmonHubTeslaPowerWallInterfacer.py | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
pi@emonpi:~ $ sudo su -
root@emonpi:~# systemctl status emonhub.service
● emonhub.service - emonHub service description
Loaded: loaded (/opt/openenergymonitor/emonhub/service/emonhub.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-07-08 18:21:54 BST; 5min ago
Process: 1265 ExecStartPre=/bin/mkdir -p /var/log/emonhub/ (code=exited, status=0/SUCCESS)
Process: 1266 ExecStartPre=/bin/chgrp -R emonhub /var/log/emonhub/ (code=exited, status=0/SUCCESS)
Process: 1267 ExecStartPre=/bin/chmod 775 /var/log/emonhub/ (code=exited, status=0/SUCCESS)
Main PID: 1268 (python3)
Tasks: 3 (limit: 2319)
Memory: 14.6M
CGroup: /system.slice/emonhub.service
└─1268 python3 /usr/local/bin/emonhub/emonhub.py --config-file=/etc/emonhub/emonhub.conf --logfile=/var/log/emonhub/emonhub.log
Jul 08 18:21:54 emonpi systemd[1]: Starting emonHub service description...
Jul 08 18:21:54 emonpi systemd[1]: Started emonHub service description.
root@emonpi:~# cd /opt/openenergymonitor/emonhub/
root@emonpi:/opt/openenergymonitor/emonhub# git fetch
root@emonpi:/opt/openenergymonitor/emonhub# git pull
Already up to date.
root@emonpi:/opt/openenergymonitor/emonhub# git status
On branch stable
Untracked files:
(use "git add <file>..." to include in what will be committed)
src/src
root@emonpi:/opt/openenergymonitor/emonhub# git describe
2.1.5-2-gd2c5dd3
