Mosquitto not starting after emonSD update & upgrade
Managed to fix it …
I found that rc.local_jessieminimal was not updated via emonPi update.
All OK after manually updating that file.
So what remains to see is why rc.local_jessieminimal was not updated via emonPi update.
Cheers.
Well done fixing. That’s for reporting. rc.local_jessieminimal has updated fine on all systems I’ve tested based on emonSD-03May16. What version emonSD are you running? Could you post a copy of ~/data/emonpiupdate.log, you should be able download the log via the Emoncms admin interface
You should be able to see looking at the Emocncms admin page or you can run
$ sudo ls /boot | grep emonSD
Hi Glyn.
I’m running emonSD-03May16. Attached emonpiupdate.log as requested.emonpiupdate.zip (1.2 KB)
Hope it helps.
Best Regards.
All looks fine from the log, can you check to see if the symlink is in place:
ls /etc/fstab -la
should return
lrwxrwxrwx 1 root root 21 Apr 28  2016 /etc/fstab -> /home/pi/emonpi/fstab
Nope…those files are not linked.
