Monitoring HW cylinders with integrated heat pumps
Specifically to the monitoring question. It sounds like there’s a way.
Regarding my two very similar replies. Was I right the first time - this method of calculating the energy required to deliver hot water includes tank losses. I understand this differs from the standard emonHP method which calculates the heat delivered to the tank (and the CoP of that).
Back to my bullets. Are these right? (My expected answers in italics):
  • It is possible to calculate CoP of hot water supply for the integrated HP cylinder by monitoring flow rate and inlet/outlet temperatures.
  • There is not an emonHP bundle that lets you monitor the cylinder CoP let alone both the cylinder and monobloc ASHP together
  • With a non-standard method and setup, there is not a way to integrate the results back into heatpumpmonitor.org
