MIssing data messing up virtual feed
Does anything in here help you: The Virtual Feed - Post-processing data on the fly
The original values are clearly long gone. All I can suggest is you use the processing steps available, similar to those you use for input processing, to test for zero (or less than a suitably low value), and replace zero or whatever with something - a constant value possibly, maybe even a NULL which should result in a straight line though I’ve not checked - that is more acceptable.
