@TrystanLea - yes, that has worked, and data is flowing again. Thanks v much!
Interesting, I wonder what caused the emonTX to freeze. @Robert.Wall we should tell folk to reset the TX as a first action to see if it all comes back to life when there are problems.
Note that the EmonTx firmware in @haffle’s case appears to be discreet sampling firmware rather than the newer continuous sampling. It might be a good idea to get you on the new continuous sampling firmware with @Robert.Wall’s cut down radio implementation once we get that released @haffle
Please let us know if it happens again, it would be good to double check each time if its the readings are not updating the EmonESP Latest Data window and if not repeat the reset until we can try the next version of the firmware.
Thankyou for bearing with us @haffle
Unfortunately, experience suggests that the problem is more often with the ESP8266. I wasn’t able to help with this because I know nothing about the ESP8266.
