MyForest
(David Bowen)
7 March 2023 19:04
102
@Rachel you might enjoy this bit where we chatted about using an accumulator in a similar fashion.
I have a sort of magic solution for that which might help you, I use the effective temperature for my weather compensation so it takes into account the wind cooling my house down:
As we all know, heat pumps are more efficient when the flow temperature is low.
I’m running a large heat pump with over-sized radiators in a 200-year old house.
A common feature of modern heat pumps is weather compensation. Often this will be a “curve” which provides a high flow temperature when it’s cold outside and a lower flow temperature when it’s warmer outside. Some even have multiple points on the curve so it’s not linear !
My control algorithm uses a simple straight line at the moment. …
