Improve efficiency: Heat the hot water when it's cold
But if the heating never stops…
I am actually sending “Force” command from a cron job, with some simple logic to decide if it wants to or not. Worst case, if internet happens to be out at that exact time, I can to force it on manually via internal controls.
Prohibiting the hot water during the other 23 hours with a large “DHW max. temp. drop” setting would in theory achieve the same effect. However, I found that the Ecodan would heat the water whenever it wasn’t prohibited, regardless of the tank temperature. [@mjr noted the same here]
I do have a little rule that boosts the heating by 0.5° at noon if there’s sufficient battery left, knowing that it’ll be replenished an hour later.
My overall heat pump strategy now is to be mostly using manufacturer’s out-of-the-box controls, with some optimisation tweaks and nudges over the top. If my hacks fail for some reason, the basic operation continues to function.
