I tried to ssh into it but asked for a password! . I have searched but I cant find anything that works. Does anyone know what the default is?
emonhp
on mine
Thanks Mate!!! that worked a treat! could find no reference to that anywhere. I am sure it has been staring me in the face but i couldn’t find it.
Thanks again
I was not saying that - not at all.
This is why I asked:
Again, it appears from what you said (and bear in mind I don’t know what you did), it was you who got it wrong. You mounted the meter alongside the existing breakers, and in doing so connected the meter directly to the busbar. This would have been dangerously wrong - you’d have no protection against a fault or overload.
What it appears he did was remove that section of busbar (so that the input side of the meter can accept a wire instead of sitting on the busbar, and connect the output (top) of the existing breaker into the supply side (bottom) of the meter, and the load side (top) of the meter to the pump.
So the power comes into your house to the Supply fuse → Supplier’s meter → Consumer unit main switch → busbar → breaker → new meter → heat pump.
Not quite. It’s here (about 1 screenful from the bottom):
Hi Robert. For info, the SDM120 meters supplied by the shop in the hp bundle physically can’t sit on the bus bar - the terminals are only large enough for 4or6mm cables and there are both live and neutral terminals on the lower edge. The bus bar has to be cut away in order for the sdm120 to fit.
Ok Thanks, My head is not right at the moment so many things to do when moving house. Not had much time to sort all this out. probably should have left it for a month or two. I have just logged into the emonhub this morning for the first time and can see an error in the log "SDM120 Not connected to modbus device
2024-12-12 08:00:10,130 INFO     SDM120     Connecting to Modbus device=/dev/ttyACM0 baud=9600 parity=none datatype=float
2024-12-12 08:00:10,149 ERROR    SDM120     Could not connect to Modbus device
2024-12-12 08:00:10,171 DEBUG    EmonPi2    Config format: new
2024-12-12 08:00:10,706 DEBUG    MBUS       Invalid MBUS data received 105 bytes 604.0 ms, count: 1
2024-12-12 08:00:10,707 DEBUG    MBUS       Decoded MBUS data: {"DateTime": [1007421755, ""], "DateTime_error": [16842752, ""], "Record_error": [67108864, ""], "Ontime": [19875537, "s"], "OperatingTime": [19875465, "s"], "Energy": [4080, "kWh"], "Cooling": [53, "kWh"], "Volume": [692.285, "m3"], "Power": [3237, "W"], "FlowRate": [1.321, "m3/h"], "FlowT": [31.5, "C"], "ReturnT": [29.37, "C"], "DeltaT": [2.12, "C"], "FabNo": [4026995, ""], "ManSpec": [13612, ""], "heat_calc": [3243.6054166666654, "W"]}
2024-12-12 08:00:10,707 DEBUG    MBUS       4 NEW FRAME :
Edit - formatted text. Moderator - BT
I tried restarting the emonhub as I read on another thread but still get the same error
MBus and Modbus are different. I don’t know much about either, so check you have the correct Interfacer in emonHub, in the meantime let’s hope someone who knows more can help you.
Oh If you don’t Know, I haven’t got a hope in hell of getting this going!
I just haven’t got time to get to understand how it all works in detail.
I thought if I bought the kit it would just work! :upside_down_face:
I don’t mean nobody else here will know. Don’t just give up, I agree it should just work, so I’m a bit baffled - from the error message seems to be indicating that the message format isn’t as expected - but it’s reading some values even if it can’t make sense of everything - hence my suggestion to check what’s actually in the emonhub.conf file. As you sound desperate, I’ll try to attract @TrystanLea or @glyn.hudson’s attention.
Thanks :smiling_face:
I do sound a bit desperate don’t I :blush:
Loads of things going wrong at the moment!
Everything is new and were getting lots of problems.
one of which is…
My new solar and battery install (not done by me) is not working and the guys need to get Giv Energy on the line to initialise it But they can’t get them to answer.
:unamused:
This is a copy of my config:
Emoncms Config.txt (6.2 KB)
Hi Again.
as Far as I can tell everything is working and I am digging into creating a dashboard ( I’m using the preconfigured one at the moment) But I still don’t know what that error means . I have emailed the help desk at the shop. But not had a reply yet.
