You might want to check out this thread: Script for feeding Honeywell Evohome data into Emoncms
I’m successfully using the Python script that was provided to get the Evohome data.
I made a few modifications, I think mainly to stop the script exiting when the connection timed out:
#!/usr/bin/python
import requests
import json
import time
import math
from sys import exit
USERNAME = 'username'
PASSWORD = 'password'
while True:
# Initial JSON POST to the website to return your userdata
url = 'https://tccna.honeywell.com/WebAPI/api/Session'
postdata = {'Username': USERNAME, 'Password': PASSWORD, 'ApplicationId': '91db1612-73fd-4500-91b2-e63b069b185c'}
header = {'content-type': 'application/json'}
# get sessionID
data = json.dumps(postdata)
error = 0
try:
response = requests.post(url, data=data, headers=header)
except:
print("Couldn't get data")
error = 1
time.sleep(60)
if error == 0:
str_response = response.content.decode("utf-8")
# print(str_response)
try:
userinfo = json.loads(str_response)
except:
print("Couldn't decode data")
error = 1
time.sleep(60)
if error == 0:
if 'userInfo' not in userinfo:
#print "not allowed - header"
# sleep for 5 minutes
time.sleep(300)
continue
# here havea connection so can get data
userid = userinfo['userInfo']['userID']
sessionId = userinfo["sessionId"]
# setup and receive data then loop and extract temperature for each device
params = ""
paramsSet = ""
url = 'https://tccna.honeywell.com/WebAPI/api/locations?userId=%s&allData=True' % userid
header['sessionId'] = sessionId
try:
response = requests.get(url, data=json.dumps(postdata), headers=header)
except:
print("Timed out")
error = 1
time.sleep(60)
if error == 0:
try:
fullData = json.loads(str_response)[0]
except:
print("couldn't decode data")
error = 1
time.sleep(60)
if error == 0:
if 'devices' not in fullData:
print("not allowed - data")
time.sleep(300)
continue
for device in fullData['devices']:
stemp = ""
if params != "": params += ","
# Add device current temperature
if device['thermostatModelType'] == "DOMESTIC_HOT_WATER": params += "hot_water_temp:"
else: params += device['name'] + "_temp:"
stemp = str(round(device['thermostat']['indoorTemperature'],1))
#stemp = str(math.ceil((device['thermostat']['indoorTemperature'])*10)/10)
params += stemp
for deviceSetTemp in fullData['devices']:
params += deviceSetTemp['name'] + "_set_temp:"
stemp = str(round(deviceSetTemp['thermostat']['changeableValues']['heatSetpoint']['value'],1))
params += stemp
#now generate the insert into emoncms
url = "http://localhost/emoncms/input/post.json?node=evohome&apikey=PUT_API_KEY_HERE&json={"
url += params + "}"
print(url)
response = requests.get(url, headers=header)
# debug - read the response and print it
del params
time.sleep(300)
