pi@emonpi(ro):~$ rpi-rw
Filesystem is unlocked - Write access
type ' rpi-ro ' to lock
pi@emonpi(rw):~$ mysqldump -u emoncms -p emoncms > copiaseguridad.sql
Enter password:
mysqldump: Got error: 1017: Can't find file: 'dashboard' (errno: 2) when using LOCK TABLES
pi@emonpi(rw):~$ cd /var/www/emoncms/Modules/dashboard/
pi@emonpi(rw):dashboard$ ls -l
total 552
drwxr-xr-x 4 pi pi 4096 Jan 6 19:01 AntiXSS
lrwxrwxrwx 1 pi pi 9 Jan 6 19:01 dashboard -> dashboard
-rw-r--r-- 1 pi pi 3657 Jan 6 19:01 dashboard_controller.php
-rw-r--r-- 1 pi pi 1279 Jan 6 19:01 dashboard.js
-rw-r--r-- 1 pi pi 43081 Jan 6 19:02 dashboard_langjs.php
-rw-r--r-- 1 pi pi 1673 Oct 30 2016 dashboard_menu.php
-rw-r--r-- 1 pi pi 10240 Jan 6 19:01 dashboard_model.php
-rw-r--r-- 1 pi pi 970 Jan 6 19:01 dashboard_schema.php
-rw-r--r-- 1 pi pi 32386 Jan 6 19:01 LICENSE.txt
drwxr-xr-x 11 pi pi 4096 Jan 6 19:01 locale
-rw-r--r-- 1 pi pi 67 Jan 6 19:01 module.json
-rw-r--r-- 1 pi pi 863 Jan 6 19:02 Readme.md
drwxr-xr-x 4 pi pi 4096 Jan 6 19:02 Views
drwxr-xr-x 23 pi pi 4096 Jan 6 19:01 widget
pi@emonpi(rw):dashboard$ cd..
-bash: cd..: command not found
pi@emonpi(rw):dashboard$ cd ..
pi@emonpi(rw):Modules$ mv dashboard dashboard.old
pi@emonpi(rw):Modules$ ls
admin app backup config dashboard.old device eventp feed graph input postprocess process schedule setup sync time user vis wifi
pi@emonpi(rw):Modules$ cd \
pi@emonpi(rw):~$ php /home/pi/emonpi/emoncmsdbupdate.php
PHP Notice: Trying to get property of non-object in /var/www/emoncms/Lib/dbschemasetup.php on line 226
{"0":"ALTER TABLE `device` ADD `id` int(11) NOT NULL auto_increment PRIMARY KEY","1":"ALTER TABLE `device` ADD `userid` int(11)","2":"ALTER TABLE `device` ADD `nodeid` text","3":"ALTER TABLE `device` ADD `name` text","4":"ALTER TABLE `device` ADD `description` text","5":"ALTER TABLE `device` ADD `type` varchar(32)","6":"ALTER TABLE `device` ADD `devicekey` varchar(64)","7":"ALTER TABLE `device` ADD `time` int(10)","8":"ALTER TABLE `feeds` ADD `id` int(11) NOT NULL auto_increment PRIMARY KEY","9":"ALTER TABLE `feeds` ADD `name` text","10":"ALTER TABLE `feeds` ADD `userid` int(11)","11":"ALTER TABLE `feeds` ADD `tag` text","12":"ALTER TABLE `feeds` ADD `time` int(10)","13":"ALTER TABLE `feeds` ADD `value` double","14":"ALTER TABLE `feeds` ADD `datatype` int(11) NOT NULL","15":"ALTER TABLE `feeds` ADD `public` tinyint(1) DEFAULT '0'","16":"ALTER TABLE `feeds` ADD `size` int(11)","17":"ALTER TABLE `feeds` ADD `engine` int(11) DEFAULT '0' NOT NULL","18":"ALTER TABLE `feeds` ADD `server` int(11) DEFAULT '0' NOT NULL","19":"ALTER TABLE `feeds` ADD `processList` text","20":"ALTER TABLE `feeds` ADD `unit` varchar(10) DEFAULT ''","21":"ALTER TABLE `graph` ADD `id` int(11) NOT NULL auto_increment PRIMARY KEY","22":"ALTER TABLE `graph` ADD `userid` int(11)","23":"ALTER TABLE `graph` ADD `groupid` int(11) DEFAULT '0'","24":"ALTER TABLE `graph` ADD `data` text","25":"ALTER TABLE `postprocess` ADD `userid` int(11)","26":"ALTER TABLE `postprocess` ADD `data` text","27":"ALTER TABLE `setup` ADD `state` varchar(32) DEFAULT 'unconfigured'","28":"ALTER TABLE `setup` ADD `wifi` varchar(32) DEFAULT 'unconfigured'","29":"ALTER TABLE `sync` ADD `userid` int(11)","30":"ALTER TABLE `sync` ADD `host` varchar(64)","31":"ALTER TABLE `sync` ADD `username` varchar(30)","32":"ALTER TABLE `sync` ADD `apikey_read` varchar(64)","33":"ALTER TABLE `sync` ADD `apikey_write` varchar(64)","34":"ALTER TABLE `users` ADD `id` int(11) NOT NULL auto_increment PRIMARY KEY","35":"ALTER TABLE `users` ADD `username` varchar(30)","36":"ALTER TABLE `users` ADD `email` varchar(64)","37":"ALTER TABLE `users` ADD `password` varchar(64)","38":"ALTER TABLE `users` ADD `salt` varchar(32)","39":"ALTER TABLE `users` ADD `apikey_write` varchar(64)","40":"ALTER TABLE `users` ADD `apikey_read` varchar(64)","41":"ALTER TABLE `users` ADD `lastlogin` datetime","42":"ALTER TABLE `users` ADD `admin` int(11) NOT NULL","43":"ALTER TABLE `users` ADD `gravatar` varchar(30) DEFAULT ''","44":"ALTER TABLE `users` ADD `name` varchar(30) DEFAULT ''","45":"ALTER TABLE `users` ADD `location` varchar(30) DEFAULT ''","46":"ALTER TABLE `users` ADD `timezone` varchar(64) DEFAULT 'UTC'","47":"ALTER TABLE `users` ADD `language` varchar(5) DEFAULT 'en_EN'","48":"ALTER TABLE `users` ADD `bio` text","49":"ALTER TABLE `users` ADD `tags` text","50":"ALTER TABLE `users` ADD `startingpage` varchar(64) DEFAULT 'feed\/list'","51":"ALTER TABLE `users` ADD `email_verified` int(11) DEFAULT '0'","52":"ALTER TABLE `users` ADD `verification_key` varchar(64) DEFAULT ''","53":"ALTER TABLE `users` ADD `preferences` varchar(255)","54":"ALTER TABLE `rememberme` ADD `persistentToken` varchar(40)","error":"Can't find file: 'device' (errno: 2)"}
pi@emonpi(rw):~$
