Not really I have explained above already that the truncate error happens independent of the actual error and therefore one must come first and it can be either. if the file truncates before the emonTH stops the tail output stops because of the truncate error or if the emonTH stops the tail session will continue until the file is truncated. It’s a red herring. Of course they can happen around the same time, but even if they don’t it could appear they had.
Whilst it is too early to rule out a rare faulty unit, it could also be the antenna touching the gpio pins, not seated correctly or even more likely a PSU isssue since the rfm will always be the weakest link when it comes to power stability.
The emonPi has a watchdog that reinitialises the rfm every so often, that isn’t in the rfm firmware, but there again the latest firmware has been pretty stable. Assuming this RFM69Pi has the latest FW and isn’t from the back of shelf.
If the RFM69Pi was physically faulty it is less likely to come to life after emonhub is restarted, that would suggest the device is being reset by emonhub restarting the serial connection. This is how the RFM issues used to manifest some years ago, there are many threads on it and at least one of them has a little test script that the user can execute instead of restarting emonhub to reset the RFM2Pi and if the data starts, we know it’s the age old issue and probably a PSU issue if running the latest FW.
When did that change? As I recall all the emonSD images have always rotated the emonhub logs way before the emonhub hardcoded rotation at 5M. Originally by logrotate only at 1M then at 3M by log2ram+logrotate more recently. I was surprised by your comment about only 0.5M but took it you knew something I didn’t.
The emonSD has a global rotation size 100k
however the logrotate config for emonhub has maxsixe 3M
and if no logrotation takes place then eventually emonhub will rotate itself at 5M
so if the rotation is happening at 0.5M I’m not sure where that is coming from.
