pb66
(Paul)
13
@TrystanLea - If you check Neils update logs they both contain
Installing emoncms logrotate...
Now setting up Logrotate...
Backing up old logrotate configuration...
Linked to new logrotate configuration...
Backing up old logrotate cron job...
mv: cannot stat '/etc/cron.daily/logrotate': No such file or directory
Linked to new logrotate cron job...
Completed
Completed
Running logrotate...
set log rotate config owner to root
the 2 "Backing up old . . . " lines suggest the backed up files are being over written on every update, there no point backing up the original files if they are going to be overwritten again with the content of the symlinked files, ideally this needs to be multi-run safe by making a backup only if a real file is found (not a symlink) as I proposed
I also think the whole update should be aborted if the emonpi repo git pull fails and failures need to be passed to the user somehow. Perhaps a flag “there were errors check your update log” could be bannered across the emoncms gui and or on the emonpi lcd?
