stephen
(stephen krywenko)
22
do you have 2 unused 3/4’’ outlets one at the top one at the bottom just insert your own into it here how to build it – Howto build a Heat buffer Tank it handle up to 36 tubes or about 2 kw until the heat differential is too high and you loose to much to the surrounding
