requests can do anything.
Thanks for the link to the relevant part of the thread. I’ll have a read.
Right I think I’m caught up now.
I think there’s no point in trying to verify the server certificate, although it is possible. It’s just too much hassle for users to set up and it is fragile. tesla-powerwall · PyPI doesn’t bother, for example.
Given that, the safest solution is to just do this:
reply = requests.get(self._settings['url'], timeout=int(self._settings['readinterval']), verify=False)
I have done as you’ve suggested (but didn’t delete newer file - just renamed it)
After a emonhub.service restart, the log file shows the following …
2020-07-05 22:38:50,631 WARNING MainThread PowerWall thread is dead.
2020-07-05 22:38:50,632 WARNING MainThread Attempting to restart thread PowerWall (thread has been restarted 1951 times...
2020-07-05 22:38:50,633 INFO MainThread Creating EmonHubTeslaPowerWallInterfacer 'PowerWall'
2020-07-05 22:38:50,634 INFO MainThread Setting PowerWall name: powerwall
2020-07-05 22:38:50,635 INFO MainThread Setting PowerWall url: http://192.168.1.124/api/system_status/soe
2020-07-05 22:38:50,636 INFO MainThread Setting PowerWall readinterval: 10
2020-07-05 22:38:50,636 DEBUG MainThread Setting PowerWall pubchannels: ['ToEmonCMS']
2020-07-05 22:38:50,796 WARNING PowerWall PowerWall couldn't send to server: HTTPSConnectionPool(host='192.168.1.124', port=443): Max retries exceeded with url: /api/system_status/soe (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1056)')))
2020-07-05 22:38:50,808 WARNING PowerWall Exception caught in PowerWall thread. Traceback (most recent call last):
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 32, in wrapper
return f(*args)
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 99, in run
rxc = self.read()
File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubTeslaPowerWallInterfacer.py", line 43, in read
jsonstr = reply.text.rstrip()
UnboundLocalError: local variable 'reply' referenced before assignment
The Certificate error rears its head …
I’ll try @TrystanLea’s suggestion - Its PROTOCOL_TLS rather than SSL … hopefully that will work
@bwduncan has suggested a line - reply = requests.get~~~~
Where do I put that?
Thx
line 38.
I added verify=False at the end of the line respecting commas, brackets & spaces.
It is now all working
… many thx to you both
I have successfully set up Log to Feed and can see a graph.
The data is also successfully being sent to watchman and I’ve set up Log to Feed & a graph there too.
NEXT STEPS …
The key things to know about a battery are …
Level of Charge - and we now have that albeit as a percentage
Discharge/Charge power at points in time … this is the next challenge
Do you have any thoughts on this?
Glad it’s working. I’ll make a pull request to make the change upstream, however
There is more that the powerwall can tell us beyond state of charge. I suspect the best way to get all this data is to use the powerwall python module someone else has already written. Once we have an easy way to get the power at the various interfaces we can do wonderful things!
I’ll see if I can hammer something together tomorrow…
I can no longer re-start the emonhub.service.
This is what status reports …
@emonpi-node-15:~ $ sudo systemctl status emonhub.service
● emonhub.service - emonHub service description
Loaded: loaded (/opt/openenergymonitor/emonhub/service/emonhub.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-06 17:28:08 BST; 1min 0s ago
Process: 14417 ExecStartPre=/bin/mkdir -p /var/log/emonhub/ (code=exited, status=0/SUCCESS)
Process: 14418 ExecStartPre=/bin/chgrp -R emonhub /var/log/emonhub/ (code=exited, status=0/SUCCESS)
Process: 14419 ExecStartPre=/bin/chmod 775 /var/log/emonhub/ (code=exited, status=0/SUCCESS)
Main PID: 14420 (python3)
Tasks: 3 (limit: 2319)
Memory: 11.6M
CGroup: /system.slice/emonhub.service
└─14420 python3 /usr/local/bin/emonhub/emonhub.py --config-file=/etc/emonhub/emonhub.conf --logfile=/var/log/emonhub/emonhub.log
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: UnboundLocalError: local variable 'reply' referenced before assignment
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: During handling of the above exception, another exception occurred:
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: Traceback (most recent call last):
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: File "/usr/lib/python3.7/logging/handlers.py", line 68, in emit
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: if self.shouldRollover(record):
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: File "/usr/lib/python3.7/logging/handlers.py", line 185, in shouldRollover
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: self.stream.seek(0, 2) #due to non-posix-compliant Windows feature
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: OSError: [Errno 28] No space left on device
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: Call stack:
Jul 06 17:28:49 emonpi-node-15 emonhub.py[14420]: File "/usr/lib/python3.7/threading.py", line 885, in _bootstrap
pi@emonpi-node-15:~ $
I previously had the problem, rebooted but the problem remains
Any suggestions - most welcome
Does the following help?
pi@emonpi-node-15:~ $ df -hT
Filesystem Type Size Used Avail Use% Mounted on
/dev/root ext4 4.0G 2.2G 1.7G 58% /
devtmpfs devtmpfs 484M 0 484M 0% /dev
tmpfs tmpfs 488M 0 488M 0% /dev/shm
tmpfs tmpfs 488M 56M 433M 12% /run
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 488M 0 488M 0% /sys/fs/cgroup
tmpfs tmpfs 1.0M 0 1.0M 0% /var/tmp
tmpfs tmpfs 1.0M 4.0K 1020K 1% /var/lib/php/sessions
tmpfs tmpfs 30M 0 30M 0% /tmp
/dev/mmcblk0p1 vfat 253M 52M 201M 21% /boot
/dev/mmcblk0p3 ext2 25G 3.5M 24G 1% /var/opt/emoncms
log2ram tmpfs 50M 50M 0 100% /var/log
tmpfs tmpfs 98M 0 98M 0% /run/user/1000
pi@emonpi-node-15:~ $ cd /var/log
pi@emonpi-node-15:/var/log $ ls -l
total 38268
-rw-r--r-- 1 root root 0 Jul 2 01:17 alternatives.log
drwxr-x--- 2 root adm 100 Jun 15 00:00 apache2
drwxr-xr-x 2 root root 100 Jul 2 01:17 apt
-rw-r----- 1 root adm 161533 Jul 6 17:51 auth.log
-rw-r--r-- 1 root root 0 Sep 26 2019 bootstrap.log
-rw-rw---- 1 root utmp 0 Jul 6 15:00 btmp
-rw-r----- 1 root adm 28778496 Jul 6 17:52 daemon.log
-rw-r----- 1 root adm 0 Jul 6 15:18 debug
-rw-r--r-- 1 root root 0 Jul 2 01:17 dpkg.log
drwxr-xr-x 2 pi root 180 Jul 5 00:17 emoncms
drwxrwxr-x 2 root emonhub 80 Jul 5 23:03 emonhub
drwxr-xr-x 2 pi root 60 Oct 17 2019 emonpilcd
-rw-r--r-- 1 root root 24000 Oct 17 2019 faillog
-rw-r----- 1 root adm 0 Jul 6 15:18 kern.log
-rw-rw-r-- 1 root utmp 292292 Jul 6 17:51 lastlog
-rw-r--r-- 1 root root 4096 Jul 6 16:17 log2ram.log
drwxr-xr-x 2 root adm 80 Jul 6 17:17 logrotate
-rw-r----- 1 root adm 81920 Jul 6 17:52 messages
drwxr-xr-x 2 mosquitto root 60 Oct 17 2019 mosquitto
drwxr-s--- 2 mysql adm 60 Jul 6 15:18 mysql
drwx------ 2 root root 40 Sep 26 2019 private
drwxr-s--- 2 redis adm 60 Jul 6 15:18 redis
drwxr-xr-x 2 root root 60 Jul 6 15:18 remoteit
lrwxrwxrwx 1 root root 12 Oct 17 2019 rotated_logs -> /var/log.ol d
-rw-r----- 1 root adm 9777152 Jul 6 17:52 syslog
-rw-r----- 1 root adm 1030 Jul 6 15:18 user.log
-rw-r--r-- 1 root root 533 Jul 6 15:18 wifiAP.log
-rw-rw-r-- 1 root utmp 52992 Jul 6 17:51 wtmp
There’s an awful lot of daemon.log - how can I reduce its size?
/var/log full (search on that or on truncate for the solution).
Are you running an up to date version of emoncms?
I’m running the latest 10.2.3
I had the file ownership issue
You are correct in yr suggestion …
I think this will fix that issue
sudo chown root:pi /opt/openenergymonitor/EmonScripts/defaults/etc/logrotate.d/*
I did indeed fix it - thx
My other 10.2.3’s seem to be getting very full too.
@TrystanLea - note issue not fully solved…
Thanks @borpin @johnbanks, looks like our pervious fix of just changing the file ownership did not work. I’ve switched to calling the command you copied above @borpin, see:
This is in stable tag 1.0.8-beta & release
To be absolutely clear - this is what I did … per @borpin’s suggestions …
Then …
sudo /usr/sbin/logrotate -v /etc/logrotate.conf
After which I could see a reasonable amount of available space in /var/log
Sorry for any confusion
@TrystanLea can you sort out emonhub too please? A whole load of PRs (not just for the Tesla) that are now starting to get really confused.
Thanks @bwduncan Shall I make this change to the emonhub interfacer?
Yes please. It will get it working until there is time to get the rest of the API being collected.
done, cheers skip TLS verification for tesla power wall self signed cert · openenergymonitor/emonhub@1da8085 · GitHub
I have made some small progress in obtaining PowerWall data.
If you substitute the following url in the EmonHubTeslaPowerWallInterfacer in emonhub.conf
url = http:// IP of PowerWall /api/meters/aggregates
… then a whole bunch of data becomes available.
The data is only available as part of an error log but at least it’s data in the Emon eco system.
To get the following log data, I commented out lines 54, 55 & 56 in EmonHubTeslaPowerWallInterfacer.py that Check if battery percentage key is in data object … which it isn’t in this url call.
Here’s the relevant bit of the log – pls ignore refs to watchman.
2020-07-08 18:43:35,756 INFO MainThread EmonHub emonHub emon-pi variant v3-beta
2020-07-08 18:43:35,756 INFO MainThread Opening hub...
2020-07-08 18:43:35,757 INFO MainThread Logging level set to DEBUG
2020-07-08 18:43:35,757 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2020-07-08 18:43:35,759 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2020-07-08 18:43:35,760 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2020-07-08 18:43:35,760 INFO MainThread Setting MQTT node_format_enable: 0
2020-07-08 18:43:35,760 INFO MainThread Setting MQTT nodevar_format_enable: 1
2020-07-08 18:43:35,761 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2020-07-08 18:43:35,762 INFO MainThread Creating EmonHubTeslaPowerWallInterfacer 'PowerWall'
2020-07-08 18:43:35,762 INFO MainThread Setting PowerWall name: powerwall
2020-07-08 18:43:35,763 INFO MainThread Setting PowerWall url: False
2020-07-08 18:43:35,763 INFO MainThread Setting PowerWall readinterval: 10
2020-07-08 18:43:35,763 DEBUG MainThread Setting PowerWall pubchannels: ['ToEmonCMS']
2020-07-08 18:43:35,764 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'To_watchman'
2020-07-08 18:43:35,765 DEBUG MainThread Setting To_watchman pubchannels: ['ToRFM12']
2020-07-08 18:43:35,766 DEBUG MainThread Setting To_watchman subchannels: ['ToEmonCMS']
2020-07-08 18:43:35,766 INFO MainThread Setting To_watchman apikey: set
2020-07-08 18:43:35,766 INFO MainThread Setting To_watchman url: http://192.168.1.10/emoncms
2020-07-08 18:43:35,766 INFO MainThread Setting To_watchman senddata: 1
2020-07-08 18:43:35,767 INFO MainThread Setting To_watchman sendstatus: 0
2020-07-08 19:26:31,478 INFO MainThread Setting PowerWall url: http://192.168.1.100/api/meters/aggregates
2020-07-08 19:26:31,479 INFO MainThread Setting PowerWall readinterval: 10
2020-07-08 19:26:38,126 INFO MainThread EmonHub emonHub emon-pi variant v3-beta
2020-07-08 19:26:38,127 INFO MainThread Opening hub...
2020-07-08 19:26:38,127 INFO MainThread Logging level set to DEBUG
2020-07-08 19:26:38,128 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2020-07-08 19:26:38,130 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2020-07-08 19:26:38,131 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2020-07-08 19:26:38,131 INFO MainThread Setting MQTT node_format_enable: 0
2020-07-08 19:26:38,131 INFO MainThread Setting MQTT nodevar_format_enable: 1
2020-07-08 19:26:38,131 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2020-07-08 19:26:38,132 INFO MainThread Creating EmonHubTeslaPowerWallInterfacer 'PowerWall'
2020-07-08 19:26:38,133 INFO MainThread Setting PowerWall name: powerwall
2020-07-08 19:26:38,133 INFO MainThread Setting PowerWall url: http://192.168.1.100/api/meters/aggregates
2020-07-08 19:26:38,134 INFO MainThread Setting PowerWall readinterval: 10
2020-07-08 19:26:38,134 DEBUG MainThread Setting PowerWall pubchannels: ['ToEmonCMS']
2020-07-08 19:26:38,136 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'To_watchman'
2020-07-08 19:26:38,137 DEBUG MainThread Setting To_watchman pubchannels: ['ToRFM12']
2020-07-08 19:26:38,138 DEBUG MainThread Setting To_watchman subchannels: ['ToEmonCMS']
2020-07-08 19:26:38,138 INFO MainThread Setting To_watchman apikey: set
2020-07-08 19:26:38,139 INFO MainThread Setting To_watchman url: http://192.168.1.10/emoncms
2020-07-08 19:26:38,139 INFO MainThread Setting To_watchman senddata: 1
2020-07-08 19:26:38,139 INFO MainThread Setting To_watchman sendstatus: 0
2020-07-08 19:26:38,278 DEBUG PowerWall PowerWall Request response: {"site":{"last_communication_time":"2020-07-08T19:26:38.190213726+01:00","instant_power":260.3262634277344,"instant_reactive_power":-142.2243995666504,"instant_apparent_power":296.64379862444514,"frequency":50.049781799316406,"energy_exported":151417.04500000057,"energy_imported":241906.8625000005,"instant_average_voltage":193.68669086797593,"instant_total_current":0,"i_a_current":0,"i_b_current":0,"i_c_current":0,"timeout":1500000000},"battery":{"last_communication_time":"2020-07-08T19:26:38.188451066+01:00","instant_power":-110,"instant_reactive_power":30,"instant_apparent_power":114.0175425099138,"frequency":50.067,"energy_exported":37100,"energy_imported":41530,"instant_average_voltage":246.43333333333337,"instant_total_current":0.30000000000000004,"i_a_current":0,"i_b_current":0,"i_c_current":0,"timeout":1500000000},"load":{"last_communication_time":"2020-07-08T19:26:38.188451066+01:00","instant_power":361.4218817850619,"instant_reactive_power":-119.27322196880134,"instant_apparent_power":380.5941120299606,"frequency":50.049781799316406,"energy_exported":0,"energy_imported":86059.81749999995,"instant_average_voltage":193.68669086797593,"instant_total_current":1.8660129932800624,"i_a_current":0,"i_b_current":0,"i_c_current":0,"timeout":1500000000},"solar":{"last_communication_time":"2020-07-08T19:26:38.190978437+01:00","instant_power":0,"instant_reactive_power":0,"instant_apparent_power":0,"frequency":0,"energy_exported":0,"energy_imported":0,"instant_average_voltage":0,"instant_total_current":0,"i_a_current":0,"i_b_current":0,"i_c_current":0,"timeout":1500000000}}
2020-07-08 19:26:38,281 WARNING PowerWall Exception caught in PowerWall thread. Traceback (most recent call last):
return f(*args)
rxc = self.read()
File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubTeslaPowerWallInterfacer.py", line 62, in read
c.realdata = [data['percentage']]
KeyError: 'percentage'
Errors are reported in lines 32 & 99 in emonhub_interfacer.py and line 62 in EmonHubTeslaPowerWallInterfacer.py.
It’s way beyond my skill level to fix those errors so any help would be most welcome.
For me and most other PowerWall users I suspect, the key info is in the “battery” section namely – instant_power, energy_exported & energy_imported.
The percentage level of charge is also important. That requires a call to url = http:// IP of PowerWall /api/system_status/soe … per the current working EmonHubTeslaPowerWallInterfacer.
This begs the question – is it possible to have two url calls within one Interfacer?
TIA for any help/suggestions
That’s a decent chunk of instantaneous data! I’m surprised that you say you are really only interested in the battery power (presumably the energy imported/exported can be integrated by emoncms or something later). I guess you have other things monitoring your grid and solar flows?
Yes, in fact we don’t even need to specify the entire URL in the config. We know the endpoints which have the data we’re interested in. We just need the hostname (or the IP address) to be specified in the conf file.
To get the data you want out of that data blob, do something like this: (set the url to “https://192.168.1.100/”)
aggregates = requests.get(self._settings['url'] + '/api/meters/aggregates', timeout=10, verify=False).json()
c = Cargo.new_cargo(names=['battery_instant_power'], realdata=[aggregates['battery']['instant_power'])
If that and the battery percentage are all you need then it can be done quite simply. Let me know if the above works for you.
