I’ve updated the code on the EmonHub repository to use PROTOCOL_SSLv23 for the time being Update EmonHubTeslaPowerWallInterfacer.py · openenergymonitor/emonhub@d4633e3 · GitHub
That doesn’t work:
ctx = ssl.SSLContext(ssl.PROTOCOL_SSL)
AttributeError: ‘module’ object has no attribute ‘PROTOCOL_SSL’
I have the script working with Python3 now ![]()
Its PROTOCOL_TLS rather than SSL … hopefully that will work
Yes indeed it does.
OK showing my complete ignorance here, how do I update the Powerwall interfacer?!
Great that the TLS options works, sounds like that might mean we’ve made a secure connection!
cd /opt/openenergymonitor/emonhub
git pull origin powerwall
sudo service emonhub restart
Did you run the above without PYTHONHTTPSVERIFY=0?
Yes, but we’ll soon find out if it really works when I update
Yay it works!
I even remebered to check I’d disabled my crontab ![]()
Output from emonhub.log:
2020-05-11 14:55:46,230 DEBUG PowerWall Request response: {“percentage”:100}
2020-05-11 14:55:46,231 DEBUG PowerWall 7 NEW FRAME :
2020-05-11 14:55:46,232 DEBUG PowerWall 7 Timestamp : 1589205346.23
2020-05-11 14:55:46,233 DEBUG PowerWall 7 From Node : powerwall
2020-05-11 14:55:46,234 DEBUG PowerWall 7 Values : [100]
2020-05-11 14:55:46,234 DEBUG PowerWall 7 Sent to channel(start)’ : ToEmonCMS
2020-05-11 14:55:46,235 DEBUG PowerWall 7 Sent to channel(end)’ : ToEmonCMS
2020-05-11 14:55:46,416 DEBUG MQTT Publishing: emon/powerwall/soc 100
2020-05-11 14:55:46,418 INFO MQTT Publishing: emonhub/rx/powerwall/values 100
As you can see, it is sunny here today ![]()
Great news, I’ve merged this in to the main emonhub branch now, would you mind switching back and testing one more time?
git checkout emon-pi
git pull origin emon-pi
Strictly
sudo systemctl restart emonhub.service
Confirmed it works. Happy days.
Trystan, before you update the Tags etc, can the default emonhub.conf be tidied up especially for the Serial interfacer please. And the documentation for the new interfacer?
Documentation updated and tags created:
- emonhub/configuration.md at emon-pi · openenergymonitor/emonhub · GitHub
- Release v2.1.3 · openenergymonitor/emonhub · GitHub
Im not sure what you meant re serial interfacer configuration @borpin?
I had to do something odd to edit the default emonhub to work with a serial interface. Can’t remember what now…
[edit] This was what I ended up with.
[[SerialTx]]
Type = EmonHubTx3eInterfacer
[[[init_settings]]]
com_port= /dev/ttyAMA0
com_baud = 115200
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
[edit] Oh I know - it isn’t in the docs at all! @TrystanLea
Could you add an explanation of pubchannels and subchannels to the docs please as well and also remove the pubchannel entry from the HTTP interfacer as I’m sure in another thread you said it wasn’t implemented. Just adds to the confusion…
This thread is most timely as later this week I’ll be installing 3 x PowerWall’s at my son’s place. He has a large 30kWp PV installation.
In anticipation I’ve set up an RPi with the Oct 2019 emon image which is fully updated via the Admin web page.
First question …
Given there’s more than one PowerWall, do I add multiple EmonHubTeslaPowerWallInterfacers to emonhub.conf or can there be multiple ‘url = ’ lines in just one Interfacer?
Second question …
Charge level is not the only interesting battery parameter. Charge/discharge power are equally important. Do you know the API’s for this info? And would each require a separate Interfacer or will multiple ‘url = ’ lines handle it?
Perhaps there are clues here …
or here … Tesla Powerwall2 data to PVoutput? - Powerwall - PVOutput Community
So instead of url = http://POWERWALL-IP/api/system_status/soe
USE url = http://POWERWALL-IP/api/meters/battery/instant_power
OR url = http://POWERWALL-IP/api/meters/aggregates/battery/instant_power
Thanks in advance
Yes, add multiple interfacers, one for each powerwall.
On the basis of the answer below I suggest not. However, I did point @TrystanLea to the Python package for the Powerwall which could in theory do it.
There is also a good node for Node-RED that could then feed into emoncms.
@TrystanLea
The PowerWalls at my son’s place are now up and running but not yet optimised.
In a browser I can go to 192.168.1.140/api/system_status/soe and PowerWall reports the battery charge level % which is great.
However, an on-site RPi running emon updated to 10.2.3 with the PowerWall interfacer included in emonhub.conf has problems.
This is an excerpt from the log:
2020-07-05 01:09:35,499 WARNING MainThread PowerWall thread is dead.
2020-07-05 01:09:35,500 WARNING MainThread Attempting to restart thread PowerWall (thread has been restarted 1 times...
2020-07-05 01:09:35,501 INFO MainThread Creating EmonHubTeslaPowerWallInterfacer 'PowerWall'
2020-07-05 01:09:35,502 INFO MainThread Setting PowerWall name: powerwall
2020-07-05 01:09:35,502 INFO MainThread Setting PowerWall url: http://192.168.1.140/api/system_status/soe
2020-07-05 01:09:35,502 INFO MainThread Setting PowerWall readinterval: 10
2020-07-05 01:09:35,503 DEBUG MainThread Setting PowerWall pubchannels: ['ToEmonCMS']
2020-07-05 01:09:41,875 INFO MainThread EmonHub emonHub emon-pi variant v3-beta
2020-07-05 01:09:41,875 INFO MainThread Opening hub...
2020-07-05 01:09:41,876 INFO MainThread Logging level set to DEBUG
2020-07-05 01:09:41,876 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2020-07-05 01:09:41,878 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2020-07-05 01:09:43,881 WARNING MainThread Device communication error - check settings
2020-07-05 01:09:43,882 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2020-07-05 01:09:44,885 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2020-07-05 01:09:45,888 INFO MainThread Setting RFM2Pi group: 210 (210g)
2020-07-05 01:09:46,890 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2020-07-05 01:09:47,893 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2020-07-05 01:09:48,895 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2020-07-05 01:09:48,896 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2020-07-05 01:09:48,898 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2020-07-05 01:09:48,901 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2020-07-05 01:09:48,902 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2020-07-05 01:09:48,903 INFO MainThread Setting MQTT node_format_enable: 1
2020-07-05 01:09:48,903 INFO MainThread Setting MQTT nodevar_format_enable: 1
2020-07-05 01:09:48,904 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2020-07-05 01:09:48,905 INFO MainThread Creating EmonHubTeslaPowerWallInterfacer 'PowerWall'
2020-07-05 01:09:48,907 INFO MainThread Setting PowerWall name: powerwall
2020-07-05 01:09:48,907 INFO MainThread Setting PowerWall url: http://192.168.1.140/api/system_status/soe
2020-07-05 01:09:48,908 INFO MainThread Setting PowerWall readinterval: 10
2020-07-05 01:09:48,908 DEBUG MainThread Setting PowerWall pubchannels: ['ToEmonCMS']
2020-07-05 01:09:48,910 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'To_watchman'
2020-07-05 01:09:48,912 DEBUG MainThread Setting To_watchman pubchannels: ['ToRFM12']
2020-07-05 01:09:48,912 DEBUG MainThread Setting To_watchman subchannels: ['ToEmonCMS']
2020-07-05 01:09:48,913 INFO MainThread Setting To_watchman apikey: set
2020-07-05 01:09:48,913 INFO MainThread Setting To_watchman url: http://192.168.1.10/emoncms
2020-07-05 01:09:48,914 INFO MainThread Setting To_watchman senddata: 1
2020-07-05 01:09:48,914 INFO MainThread Setting To_watchman sendstatus: 0
2020-07-05 01:09:59,280 WARNING PowerWall PowerWall couldn't send to server: HTTPSConnectionPool(host='192.168.1.140', port=443): Max retries exceeded with url: /api/system_status/soe (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1056)')))
2020-07-05 01:09:59,307 WARNING PowerWall Exception caught in PowerWall thread. Traceback (most recent call last):
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 32, in wrapper
return f(*args)
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 99, in run
rxc = self.read()
File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubTeslaPowerWallInterfacer.py", line 49, in read
jsonstr = reply.text.rstrip()
UnboundLocalError: local variable 'reply' referenced before assignment
It seems to be an SSL Certificate error that’s the problem?
I really would appreciate your advice/suggestions
Many thx
